06-10-2017, 03:00 PM | #31 |
Hi all! Thanks.
Please, stay close to this thread, as you can. I will need help! The work has started. For start I have a question. Do I HAVE to remove, cover, head and cilynder apart, or could I remove 3 parts altogether? |
06-10-2017, 03:22 PM | #32 | |
06-10-2017, 04:18 PM | #33 |
You will have to remove the cylinder.
06-10-2017, 04:43 PM | #34 |
Is the bolt for the flywheel and magnet straight thread or reversed thread?
06-10-2017, 05:33 PM | #35 |
Piston and valves...Are these carbon deposits OK?
Spark plug, is it a little lean? |
06-10-2017, 09:09 PM | #36 |
I think it is a little rich. But the question is - how fast was it ridden by the previous owner. If it was ridden pretty fast, could be main jet is a little rich. If he rode it more between 30 -50 mph, the needle could be the culprit, meaning that the clip is too far down the needle...ARH
06-10-2017, 09:24 PM | #37 |
Hey, new moment. I thought that this engine has 69x53mm bore and stroke, but I measured about 63x63mm bore and stroke. This coresponds to 163FML engine, and mine should be ZS169FML. What is going on?!
I pretty much disassembled the engine. I have to remve the magnet with some puller, and to make a tool for centrifugal oil filter (ARH, yes, it has it). Filter has done nice job, btw, but no big particles, only metal dust. I see broken tooth only on the input shaft kick starter gear. Is there a specification for clutch plates minimum thicknes? I see there are friction plates, and other metal plates. Are both changed or only the friction plates? |
06-10-2017, 09:58 PM | #38 |
d/l a shop manual https://josemaco.files.wordpress.com...h-62ktjam5.pdf
[friction] Wear limit:2.6mm [metal] Check -Any cracks? -Wrapage? Put on flat surface (glass...) is easiest method / Holes that holds oil ... These thingy is reusable in most case... --- Typical ZS CG200 IS 63.5mm https://item.taobao.com/item.htm?id=524001789602 | 63 is Loncin https://item.taobao.com/item.htm?id=36309545428
06-10-2017, 11:28 PM | #40 |
QC/T just a industry standard (ie. Non-mandatory) http://www.antpedia.com/standard/6782608-1.html . U can call it whatever in EXPORT versions...
06-11-2017, 09:55 AM | #41 |
Hi,
I have very big problem here. See the pic: The bearing has desintegrated, but the outer sleeve of the bearing is inside, you can see it in pic. I haven't found any balls or needles from bearing. Also, inner bearing sleeve is missing. There is also some damage on the aluminium housing. First, I would have to remove the metal sleeve from the housing, which is problem to me. It is fixed tightly. Transmission looks good except for 1 missing tooth for the kick starter ring, which is not very important. |
06-11-2017, 12:17 PM | #42 |
OK, I managed to get out the remaining part of bearing. Can someone give me code for new bearing, I would put some quality bearing, like SKF or similar.
06-11-2017, 01:14 PM | #44 | |
06-11-2017, 01:37 PM | #45 | |
