Old 05-07-2012, 12:57 PM   #31
I'll grab the tire sizes for you guys when I get home from work, my Konker has Bridgestones on it. The back tire is way wider than the front one, I'm guessing the back rim is at least an inch wider as well, I'll post the rim size as well as the tire size.
Old 05-07-2012, 02:20 PM   #32
Originally Posted by Brockway
Are your front and back SM rims the same? I've been looking around for some good street tires at 17x2.5 and it is surprisingly hard. Closest I've found are IRC NR53 moped tires. Are there other tire sizes you can mount on 2.5s?
The rim size is 17x2.50; the tire sizes for this rim would be about an inch wider than the rim.
Old 05-07-2012, 03:04 PM   #33
Thanks Stew. I want to choose tire sizes wisely for Son of Weldangrind.
Old 05-07-2012, 04:00 PM   #34
Brockway   Brockway is offline
I am now officially confused. So my 17x2.5 rim is supposed to have a 17x3.5" tire?
Old 05-07-2012, 04:05 PM   #35
A size 17x2.50 rim will probably accommodate a size 3.50-17 tire. The rim measurments are different from tire measurements. The rim width is measured at the base of the side flange, not the outside of the side flange. Also, a tire must be wider than a rim, or you would easily damage the rim when striking any object at the side of the tire.
Old 05-07-2012, 04:06 PM   #36
I'm just gonna wait for Stew's reply on the tire sizes. It's working for him, so I'm gonna try to replicate his sizes.
Old 05-07-2012, 04:09 PM   #37
If you check the manufacturer's tire fitment quides, they will tell you what size rims are appropriate for any size tire. You want to make sure you get the correct size tire for the rims on your wheel. Otherwise, the tire will not mount properly, and also will not inflate properly. This results in improper handling of the bike, and undesirable tire wear.
Old 05-07-2012, 04:11 PM   #38
I'm think you're wise to follow this path, Weld. I was trying to help Brockway understand the difference between rim sizes, and tire sizes.
Old 05-07-2012, 04:12 PM   #39
Not only that, but you can create a minimized contact patch, even though the tire mounted and inflated properly.
Old 05-07-2012, 04:17 PM   #40
I'm surprised how many people don't follow the manufacturer's tire fitment guides. The Honda XR650L owners are notorious for trying to fit the widest possible tire on the rear wheel. :roll: All tires are designed to accommodate a certain rim size; people should follow the manufacturer's recommendations.
Old 05-07-2012, 04:29 PM   #41
I think if Roger's 50HP KX uses a 110, that ought to be enough for most eny bike.
Old 05-07-2012, 04:31 PM   #42
I agree! The XR650L guys want the widest possible tire strictly for "poser" status. Some of these guys do very little off road riding, yet they want the oversize tires mounted on their bikes. :roll:
Old 05-07-2012, 04:35 PM   #43
I mounted a gigantic rear tire on Son of Weldangrind's XR200R, but that's only because it was free.
Old 05-07-2012, 04:40 PM   #44
For reasons I've discussed in the past a large meaty rear knobbie HURT the performance of my Q on and off road.
Even my KLX's on road performance (practical top speed and mileage) was hurt by the very aggressive 606's I fitted.
On the trail though they are excellent and that's why they are there.
Old 05-07-2012, 04:57 PM   #45
FREE is an excellent reason to mount such a tire! Hubris is not a good reason. :roll:
