05-24-2018, 08:06 PM | #31 |
Yeah I'm starting to get that and on your valve advise I'll probably try more clearance at next oil change (which is likely in 100 miles if it reacts like the last 100). I won't complain if it goes 300 though. 👌
09-18-2019, 11:20 AM | #32 |
is there such a thing as too much ticking for the valves? also the screw to see top dead center on mine stripped out. idk how to get it off now. any ideas?
09-18-2019, 12:38 PM | #34 |
what about the ticking? is there such a thing as too much?
09-18-2019, 12:52 PM | #35 |
sorry I'm a valve adjusting noob and it was the only thing I had trouble with in terms of tinkering.
please allow others to chime in here. |
09-18-2019, 02:42 PM | #36 |
Yes, there is such a thing as too much ticking. Instead of a tap tap sound it becomes more of a knock or slap sound, that is too much. The only way to know the difference is by experience as it is something hard to describe. Either way, this type of valvetrain is noisy by nature.
09-18-2019, 05:19 PM | #37 |
would you say the volume of it would make the difference? if it real loud or not?
09-19-2019, 04:03 AM | #38 |
There's alot of things that can be done here. Being that the head of that screw is a rather large diameter I would take a chisel and put a good indentation in the outer edge of the head and then I would put a punch in the indentation and tap it at an angle in the direction you want it to turn. It shouldn't take much, maybe a couple taps.
08-02-2020, 07:05 PM | #39 |
First time enduro purchase so I dont know what to expect. At first before the lifter adjustment it only ticked (or clicked) at a higher (Mid) RPM. Now that I have painfully adjusted to a .003 intake and .005 exhaust I get the clicking though out the spectrum. I found that when tightening the set nut .002 higher (.007 for the exhaust) it came in at a tight .005 because I couldnt stop the set screw from tightening while setting the set nut.
Reading multiple posts with the same catch phrase "Clicky is good" makes me feel better. (but of course how much is too much?) "How much clicky is too much clicky"
~ toys in the cave (in the order of addition) 81 Honda XL185s {work in progress} 2018 QIYI Coolster 3150CXC 150cc Quad 2019 QIYI Coolster 125cc Quad 2021 Roughhouse 50 (neat little scooter for the wife) 2022 QIYI Coolster 3150DX-4 I may not be fast but I am "Half-Fast" |
08-02-2020, 11:18 PM | #40 |
Loud valves save lives is a saying among the pushrod bike crowd.
How loud is too loud? Well, that's the thing. It's almost that you'll know. It won't sound healthy. A little tick and rattle in there means there's space for valves to move. If it sounds sort of cringy and makes you question it, double check your work. |
08-03-2020, 12:41 AM | #41 | |
I set both to 0.003" on mine and it's a little tappy, but seeing as how factory set them to basically 0 lash, it's quite good. |
08-03-2020, 04:06 AM | #42 | |
