Old 04-15-2019, 07:54 AM   #31
PhildoScaggins   PhildoScaggins is offline
Originally Posted by Whisky View Post
You need to grind on the frame where the swingarm mounts a tiny bit. As for the rubber bushings. They wear out sooner and I myself didnt want to take arm off again plus they make the bike feel much more solid. I wanted better adjusters without modding the adjuster some they won't fit in the clone arm and being $180. + For the arm extension w/adjusters I wasn't about to do any grinding on them.
Thanks for the heads up! I think my swingarm is coming today. Where on the frame will I need to grind? Probably will make sense when I try to bolt it up?
Old 04-15-2019, 01:22 PM   #32
Whisky   Whisky is offline
Whisky's Avatar
Yeah u will know, where it bolts to the frame, some ground the swingarm but since I have the brass bushings I did the frame.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 04-15-2019, 01:27 PM   #33
Whisky's Avatar
I did find out that u can swap the gear sensor from the 125 to the 190 and it will show at least N 1 2 3 4 maybe 5th
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 04-15-2019, 02:21 PM   #34
Looking at pictures of one, it looks like a very simple swap! two screws and thats it?
Old 04-15-2019, 05:03 PM   #35
scoot newb   scoot newb is offline
scoot newb's Avatar
How do you connect a gear indicator from the 190 to the cluster? I didn't notice any wires for it coming from the engine (pictures only).
Old 04-15-2019, 10:00 PM   #36
Whisky's Avatar
You install the sensor from the 125 to the 190
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 04-25-2019, 08:19 AM   #37
Finally got my old swingarm off last night. Take about a blade length off of the right side of the frame?
Old 04-25-2019, 09:16 AM   #38
Whisky's Avatar
Yep. Easy money.....
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 04-25-2019, 09:24 AM   #39
sweet. I figure with everything torn apart I might as well replace my rear sprocket as well. Is the grom sprocket a direct fit do you know?
Old 04-25-2019, 04:27 PM   #40
Whisky's Avatar
Yes bolts right on. Also a good time to put grom wheel bearings in if u ever have plans to swap in a 190cc. I also changed the rear hub and the rubber pucks to Grom in preparation for the 190. I am amazed by the difference in quality, huge improvement.
from this...
to this
Heres the sprocket I got-this is a 32t I currently have a 34t on the bike.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 04-25-2019, 08:08 PM   #41
Awesome. I'm probably gonna get everything together and running before I get new sprockets and a chain. I'll probably upgrade the hub and bearings at a later date. Tonight I grind the frame. Kinda nervous lol.
Old 04-26-2019, 01:35 AM   #42
Whisky's Avatar
I'm sure it all went fine.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 04-26-2019, 08:19 AM   #43
It did! Luckily I had some friends to hold the bike up, and hold a flashlight for me. Have you done your motor swap yet? I'm curious if the carby needs tuning or if its good to go right out the box. Still have not really looked into how to mount the oil cooler either.
Old 04-26-2019, 10:40 AM   #44
Whisky's Avatar
No not yet. I have a few more things I want to do first. I heard a re-jet is to be expected on the carb and the oil cooler mounts on the bracket where the horn is and then just mount the horn somewhere else. I'm guessing it's probably going to be a mid to late summer project. I already have the motor but I just have to many other things to do first.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 04-26-2019, 10:46 AM   #45
Whisky's Avatar
If your somewhat mechanically inclined it should be just a couple hours job, I know forsure it won't take long. I think changing the swingarm is probably more involved than swapping the motor.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
