07-01-2016, 10:44 PM | #46 |
Hi Adam!
Thanks for posing the question, and thanks also to everyone else for chiming in. I'm surprised than nobody has mentioned these: 1) A longer kick stand. My Hawk leans over at an uncomfortable angle unless I prop it up with at least 1 piece of 2x4. For "parking" purposes I have two 2x6 pieces screwed together (3" thick). Several of the "Dealers" the web have Hawks that are propped up on a 2x4 or leaning against a wall . 2) Rubber components that don't crumble in less than a year. I bought my Hawk in November of 2015 and the following rubber components have already failed: fork (accordion) boots, caliper pin boots, brake bleeder caps, and front master cylinder banjo bolt dust cover. While the banjo bolt cover doesn't matter, the rest allow dirt to get into places where it shouldn't. And in most cases ruin seals that aren't easy to replace. 3) A speedometer that doesn't read 65 MPH when my GPS says that I'm doing 55. 4) Rear turn-signal brackets that don't bend when my short legs don't make it over the seat all of the way. The brackets on my Hawk are made of very thin gauge sheet metal... 4) Either a battery cage that isn't welded into the frame at a 30 degree angle (which makes it difficult to keep acid in the battery), or an AGM battery that won't leak. When new my bike wouldn't hold a charge and I got tired of kicking it over. Within a week I replaced the lead-acid battery with LiFePO (which is overkill, cost me about 200, but never needs to be kept on a battery tender). 5) A rear shock with preload adjustment to compensate for different rider weight and overland travel loads. 6) Better cable routing for clutch and speedo. Most likely because I'm daft it was a process of trial and error before I found routes for both cables so that they didn't catch on anything. Has anyone else had their speedo cable get wrapped around the horn? 7) A swingarm "chain rail" (the part that wraps around the front of the swingarm) that matches the intended chain line. The one installed on my Hawk pushes the chain in a direction that it ain't supposed to go. 8) A rear tire that doesn't rub against the chain. The 5.10 knobby that came on my bike is both masculine looking and aggressive. But not good for either on-road traction (especially wet weather) or chain life. Although it did keep the tire-side of my chain very shiny. 9) A pre-cured ceramic coated exhaust system. If not that, then stainless as others have suggested. But ceramic paint is cheaper than stainless steel. Any exhaust paint, though, if not cured properly will burn off in the first 10 minutes. 10) Foot pegs that are wide, serrated, and level. Maybe I got a Friday bike, but mine looked like they needed Viagra. Both were pointing down at the ground. These aren't complaints. I love my Hawk and hope that it lasts until I'm old and gray.
The short list: 2011 Suzuki Boulevard C50T 2021 Chongqing Liyang Jiayu Hawk 250 DLX EFI 2017 TaoTao CY50-B scooter 79cc big bore kit - 45 MPH! (sold) 2015 Haosen Hawk (sold) 2002 Honda XR100R - project bike almost done. 2013 V-Strom 650 Adventure (sold )-: If I listed every bike that I've ever owned you'd either 1) Get bored 2) Be somewhat envious, or 3) Wonder: "What's wrong with that guy?" |
07-02-2016, 01:17 PM | #47 |
Csr...valid concerns all!
The reason we tolerate this...average price...about $1450
07-02-2016, 01:33 PM | #48 | |
Hahahahahaha! You just described every low-cost Chinese enduro offered in the US for the past 10 years!!
07-30-2016, 06:41 PM | #49 |
my top complaint and thing i would, will change is there is no beadlock on the rear tire forcing us to run a very hard tire pressure, literally making the bike dangerous om the trail.
i bought a bead lock for it and hosnestly at $5 why is this missing? the hawk is all over the trail and needs at least 15 psi dropped out of the tire. but run even 32 psi without a beadlock and your air nozel will be ripped right out of the innertube. id rather be all over the trail than stranded with a flat. |
11-08-2016, 02:57 PM | #50 |
I had to drag this one back up. Members have answered the question and posted what they thought. Are any of them being done on future Hawks?
My list would be. 1. 45 tooth sprocket on rear. Not going to cost any extra because you still need a sprocket. This seems to be the perfect size. 15 front stock is good for off- road and some highway. The owner can upgrade to 16 or 17 tooth. 2. Having a tachometer would be great or just have the Digital cluster that Matt sells. 3. O-ring chain since most of us will do off-road. Dirt and sand eat these chains up. At least the dirt will stay on the outside of the chain and not get in the bearings of the chain. The chain that comes on the Hawk is junk. 4. A chain guide that is in line with the chain and not at a skew. You would think this would of been right from the beginning. 5. Provide a proper size stock jet 110 seems to be the correct size and a couple of extra jets so the owner can change out to tune for different elevations. My Cheap Wen generator came with 2 extra jets. Not going to break the bank. And remove the tamper proof screws and cap for idle mixture. 6. Kick stand could be a little longer. Making the changes can't cost more than $50 more if that. These few and minor items will make this a better product. But then again we wouldn't need this forum if it didn't have issues.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-08-2016 at 05:55 PM. |
11-08-2016, 08:20 PM | #53 |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-09-2016 at 07:54 AM. |
12-18-2016, 04:06 PM | #54 |
Let me start by saying I love the hawk. But with the increase of small dual sport bikes from Japan and Germany these Chinese bikes days are numbered. They are playing catch-up. What has hurt the hawk the most is lack of a good parts supply and just down right terrible dealer support. Any bike you have to modify right out of the box, lie to get a tag for it and comes with a sticker that says off-road use only. It's only a matter of time till it fades away as a dual sport. The thing that you can do to the hawk is start over get it D.O.T or C.A.R.B certified for on road use, screen your dealers better, Get a handle on quality control and get a parts supplier network in place because the one you have now is not the best even e-bay is better. The bike is a good bike its just to much trouble to own. Cheap is nice but when it comes to a motorcycle do you want to stake your life on it? Because the hawk is only one lawsuit away from being no more as a dual sport. CSC has the right game plan for its bikes and I hope they make it.
P.S I own and ride a hawk everyday do I trust it no but still love it. Keeps me on my toes. Last edited by shawn66; 12-18-2016 at 05:48 PM. |
12-18-2016, 06:17 PM | #55 | |
I too have a Hawk and had to register it in a neighboring state. I certainly wish there was a DOT tag on it. I think the dealer issue isn't the death nail of the hawk but it is certainly holding it back from going prime-time. Just look at the scooter market. They are eveywhere and mostly Chinese. |
12-18-2016, 07:40 PM | #56 | |
12-18-2016, 08:46 PM | #57 |
Pay $4995 for a Honda CRF250l or $4800 for the new BMW 310 ride them for a year or two the resale will still be up there. The Hawk you can't hardly give them away. So in the long run you can come out to the good. CSC is a real threat with there customer support and warranty. From what I have been reading there are a lot of small dual sports on there way its the fastest growing motorcycle segment.
12-18-2016, 09:49 PM | #58 | |
12-18-2016, 10:02 PM | #59 |
When I went to buy a dual sport the quote was $5,700 out the door. They charge to put it together, tax (6.35) and reg. If I drove it for a year I could at best get $4,000.
Currently I'm into my hawk for under that: 1,200 shipped 30 carb 15 jets 100 cluster 10 charging adapter 115 reg and tax 1,470 all in. If it turns to dust in 2-3 years I still am ahead. If this was my daily mode of transportation or I was doing the Baja 1000 of course the hawk is not the bike. For the trails around here and the back roads I use to get there this bike fits the bill. As for the Brozz, I would have gotten that if it had 18/21 tires. |
12-18-2016, 10:05 PM | #60 | |
