Old 01-01-2014, 07:14 PM   #61
katoranger's Avatar
Here is some video.
Old 01-01-2014, 07:19 PM   #62
Originally Posted by katoranger View Post
I found the helmet on ebay. Lightly used fulmer helmet. It has to be pink.
But, of course!
Old 01-01-2014, 07:22 PM   #63
That's a nice video! The go cart is running great!
Who did the driving, and who captured the video?
Old 01-01-2014, 07:25 PM   #64
That is a sweet unit! I didn't think it would take you long to get it all sorted out .
Looks like it goes forward just fine now!
Old 01-01-2014, 08:02 PM   #65
katoranger's Avatar
Spud, Briana was driving and I took the video. Kart is running good. I have the shift cable adjusted almost all the way to keep it in forward gear. I think that I am going to make a lockout that will hold the shift lever in forward.
The chain "adjustment" worked. Still had some popping noise when doing donuts. I think a new chain and some more cutting on the adjuster is needed. I believe that the stock engine mounting is not really adequate. I have some ideas to improve it.
Old 01-01-2014, 08:37 PM   #66
I heard a man laughing during the video recording, so I wondered who was driving. For someone who just learned to drive, Briana cuts a pretty good doughnut.
Old 01-01-2014, 08:45 PM   #67
Kid Heaven right there, in Kansas!
Old 01-01-2014, 09:07 PM   #68
katoranger's Avatar
She was backing trailers with the tractor today too.
Old 01-01-2014, 10:33 PM   #69
You must be a good teacher, Allen.
Old 01-02-2014, 01:48 PM   #70
Awesome vid! It looks like the buggy really sccots along well. Are the yellow clutch springs and large yellow spring meant to work as a system, like a colour code? In your research, what other rpm engagement ranges did you find? Does it work well with you in it?
Old 01-02-2014, 08:40 PM   #71
katoranger's Avatar
The yellow was the recommended color. They make a red that is even higher engagement. That would be for hill climbing.
Went out tonight so we could pull the sled in the snow. The throttle cable snapped. I think it froze. Rigged a temporary one and got some sledding done.
Old 01-02-2014, 08:42 PM   #72
katoranger's Avatar
Yes, the yellow springs come together as a package. The stronger large torque spring is to force it into the downshift position faster.
Old 01-06-2014, 10:48 AM   #73
Do you find that the sliders allow a little higher rpm?
Old 01-06-2014, 11:53 AM   #74
katoranger's Avatar
The sliders seem to work well. I didn't really get a chance to compare, but in my opinion it seems to have a good top end. I don't think it lost any.
If you are going to work on the new ATV I suggest taking the clutch pulley apart and cleaning out the old grease and installing new quality grease. I didn't do it on the buggy and now the cold weather is making it sticky until it gets warmed up.
Next I want to change sprockets. I think a tooth less on the engine or a few teeth more on the axle.
Old 01-06-2014, 04:01 PM   #75
I'm thinking that I also want to bump up rpm engagement to compensate for those tall tires.
