Old 07-31-2016, 12:08 AM   #61
MDStroup   MDStroup is offline
MDStroup's Avatar
Originally Posted by hertz9753 View Post
pc doesn't want to be my friend on FB. Maybe the Michael thing confused him?
What?
Old 07-31-2016, 12:16 AM   #62
pcspecialist   pcspecialist is offline
I get a lot of friend requests, yours was buried in a bunch of others.
Old 07-31-2016, 07:42 AM   #63
LunaTech   LunaTech is offline
LunaTech's Avatar
Great pics of the bike. I just sent you a friend request also. My FB pic is the same as my avatar here.
Jeff
Old 07-31-2016, 08:37 PM   #64
What good are friends? Do we get coupons for the Outback Steak House?
Old 08-01-2016, 02:15 AM   #65
hertz9753's Avatar
Are you giving out coupons to your backyard?
Old 09-02-2016, 01:19 PM   #66
I just discovered that I never updated this thread with photos of the new side covers I got from CSC. My Hawk is a little less green now and the black of the tank extends into the panels. The two pieces were not meant to be the same color, that's why the larger piece has a window slot revealing the smaller piece.
http://www.cscmotorcycles.com/TT250-...p/zt30-103.htm
http://www.cscmotorcycles.com/TT250-...p/zt30-109.htm
Old 09-02-2016, 01:30 PM   #67
I previously posted about this, but, it belongs in this thread. On the left is the "fuel sensor" I got from CSC and on the right is the one that came with my Hawk. Is it any wonder the factory sensor was registering empty 1/2 tank and below? It was too short to get anywhere near the bottom of the tank. BTW, the factory one (on the right) originally had the bend next to the float at a 90 degree angle but I had corrected that shortly after getting the Hawk. The CSC one on the left shipped as you see it.
http://www.cscmotorcycles.com/TT250-...-p/zt8-113.htm
Old 09-02-2016, 01:39 PM   #68
jet321   jet321 is offline
Where did you get your hand guards? I got some but one has already broke due to cheap plastic.
2015 Hawk 250 ~ Aftermarket Exhaust/K&N/LED everything/16/44T/Shinko 705's
Old 09-02-2016, 01:57 PM   #69
#44 (on page 3) in this thread
Old 09-02-2016, 01:59 PM   #70
Topeak Mountain Morph Bike Pump
https://www.amazon.com/dp/B000FI6XJE
Old 09-02-2016, 02:05 PM   #71
Better mirrors (in case you missed my comment about them earlier in this thread):
https://www.amazon.com/gp/product/B016DRCZ6K
Cruise control (an o-ring):
https://www.amazon.com/dp/B00BQ1BL46
Handle Bar Ends Grips Heavy Weight:
http://www.ebay.com/itm/172090290044
Engaged:
Disengaged:
Old 09-08-2016, 04:15 PM   #72
vicbarber   vicbarber is offline
where on the muffler did u drill the holes?
Pretty much finalized my exhaust mods so I've copied over all the info from another thread. I had already decatitated the exhaust and drilled holes in the muffler, but, didn't notice much of a power gain so I decided to increase the opening on the end of the muffler by replacing the stock insert with a Pro Circuit one (which is a bolt in replacement). It doesn't fall flat on it's face past 6K RPMs like it used to so I'm now shifting at 8K RPM (when trying to get up to speed quickly) and can really feel it pull with EVERY shift. I could do 55MPH comfortably all day long, even sustaining 60MPH is no problem at all if not fighting a wind.
Drilled holes inside muffler with a long bit I have for running cables to reduce back pressure. The plate inside the muffler is further away than the zoom lens make it look like. Probably too many holes, wish I had used the larger insert instead of stock one when I was test driving between hole drilling (there are more than you see in the picture).
With the insert installed
Here it is all polished up:
This is the insert I purchased, but, what I received does not protrude into the muffler so I won't be able to hose-clamp a screen on the inside as I wanted.
http://www.amazon.com/gp/product/B001654JK0
Code:
don't know why it keeps changing it to amazon.ca (where you can't even get it) here's the url you need: http://www.amazon.com/gp/product/B001654JK0
Old 09-11-2016, 01:06 PM   #73
Nithious   Nithious is offline
Nithious's Avatar
Send a message via MSN to Nithious
Thanks for the idea on the seat cover, I was scratching my head on how to get it to snog in perfect.
[ATTACH][ATTACH]Name:  IMG_0977.jpg
Size:  95.0 KB[/ATTACH][/ATTACH]
Old 12-13-2016, 10:33 PM   #74
I cut off the buckles (leaving the loops intact) and drilled some holes in the seat pan to get a Coleman Comfort Ride(TM) Seat Protector to fit like a glove. http://www.amazon.com/dp/B006JMK7N8
Code:
Trunk fit beautifully, just needed some large nuts to raise it enough that I can get the seat on and off and the rear slots had to be filed a little bit to line up with the bolt holes on the Hawk. The trunk is easily removed, just turn the key and press a button. Now I just need a tank bag and some saddle bags.
http://www.ebay.com/itm/351721854900
12" X 3.5" OWNER MANUAL CANISTER
http://www.ebay.com/itm/111693466254
NGK (2202) DPR8EIX-9 Iridium IX Spark Plug
http://www.amazon.com/dp/B000CSGWZC
MSR DR-Z400 shifter (1 inch longer than stock)
http://www.amazon.com/dp/B000WJAVJ4
With the stock carb, I removed the plug over the idle mixture screw and turned it out 1 3/4 turns. I used a center punch to indent and then tap off the tamper proof screws, shimmed up the needle with three #4 washers and replaced the main jet with a large round size 110 (N100.604/110).
http://www.ebay.com/itm/171069472877
Replaced the front sprocket with a 17 tooth one. Discovered you can't get the cover back on with the chain on the 17 tooth, have to put the chain on after the cover is installed.
http://www.amazon.com/dp/B004DNA0KA
my cover went on with the chain on just had to find that one elusive spot for it to clear everything.
Old 12-18-2016, 08:04 PM   #75
MDStroup's Avatar
Good find on that. Thanks for the heads up
