Thread Tools Display Modes
Old 12-28-2015, 01:10 PM   #76
I'm surprised that the voltage cutoff circuit can handle the load of a heated jacket. If LiPo batteries shouldn't be discharged beyond a certain point, I can see where a heavier version of the cutoff circuit would be a benefit at a LiPo motorcycle battery.
I like that flanged SAE battery connector. I see no reason why a battery maintainer couldn't be plugged in at that point over the winter.
Although it is rated high enough to handle the load of my heated jacket, the voltage cutoff circuit I was using finally failed. Therefore, I switched to a different, voltage cutoff circuit which is rated for 6 amps.
http://www.ebay.com/itm/1x-PCM-Prote...8AAOxyjxlTOmyj
Old 12-29-2015, 11:13 AM   #77
Do you have any pics of the installation of the new voltage cutoff circuit?
Old 12-29-2015, 10:20 PM   #78
This afternoon I took a photograph for you. The protection circuit module is located inside the red boundary. After soldering the appropriate connectors on both ends, I protected the printed circuit board (PCB) with several layers of shrink tubing.
Old 12-29-2015, 11:38 PM   #79
Thanks, Spud. I hope the new circuit works out well for you.
Old 12-30-2015, 12:07 AM   #80
You're welcome. The new circuit is very robust, and it has been working well for about 6 months. This circuit is definitely superior to the circuit I tried initially.
