10-17-2017, 08:02 PM | #76 | |
10-17-2017, 08:21 PM | #77 | |
10-17-2017, 11:32 PM | #78 | |
10-18-2017, 12:24 AM | #79 | |
I would try the coke/solvent method and give that a shot first though. Tey to rule out everything else before it requires tearing into the motor.
10-18-2017, 10:46 AM | #80 |
Megadan summed up my thoughts exactly, although he articulated them better.
10-18-2017, 11:00 AM | #81 | |
10-18-2017, 11:31 AM | #82 |
When i start it up and after about 2 mins at idle it starts to smoke. If i rev it to mid throttle clouds of smoke comes out. Let it back down to idle and smoke in not as bad. Rev it up again alot of smoke comes out. Riding it aroumd back yard doesnt smoke as bad. Ride it back in garage and rev it smokes pretty good again. Seems to smoke the worse when i let it idle the rev the gas. I havent riden it more then 10 mins at a time due to limited space. You can see in my pics the exhaust valve is pretty caked with burnt oil and some oil sludge on the outside of the cylinder due to exhaust leak. Gonna put a little sea foam in sparkplug hole and let it sit. Gonna add a little to oil and fuel to see what happens. Aint gonna hurt it any worse
10-18-2017, 11:47 AM | #83 |
I agree with Megadan. Everything else looks good. I had a Honda 200x that the exhaust valve stem seal was going bad. Smoked like crazy when it set for a while or over night. It would smoke for about 2-3 minutes and then would clear up. Piston and plug would be clean as can be. It really didn't consume oil and had me puzzled with all the smoke. I pulled the header pipe off after it set overnight and sure enough that were the oil had leaked. Only difference was it would stop leaking after it warmed up. I never did change it. It ran fine for years.
10-18-2017, 12:48 PM | #84 | |
10-18-2017, 01:21 PM | #85 |
You can try on of the local MC shops. Bring the old one and they could match it up. It's a shot in the dark but without exact measurement to check it this might work. http://www.cscmotorcycles.com/TT250-...p/zt39-102.htm Take some measurements and give them a call or maybe one of the members on here can take a measurement. You can also search on Ebay and find them.
You can pressurize the cylinder or what I have done is use a piece of small diameter rope in spark plug hole and let I coil up on top the piston then rotate the engine till it puts pressure on the valves to hold in place.
10-18-2017, 01:42 PM | #86 | |
10-18-2017, 02:38 PM | #87 | |
10-18-2017, 08:45 PM | #88 |
Ok on lunch I put some sea foam in the spark plug hole at tdc. Let it soak for 4 hours. Don't know if it evaporated within those 4 hours but some was def gone. Turn motor over to rid any left. Fired it up and now have a pretty good rattle sound. It had a slight rattle before I did all this but now the rattle is much louder. Sounds like valve chatter to me but not sure. Readjusted valves once fully cool and they were a little off. Slightly tight. Compression still 140psi. Fired it up again and still smokes and chatter is still there. A lot more noticeable at just above idle. If I end up rebuilding the top end can I make it a 250(230)? Direct Bolton?
10-18-2017, 10:16 PM | #89 | |
10-19-2017, 07:45 AM | #90 |
Did you check the oil if the Seafoam leaked down into the base? Oil may be thinned out from the Seafoam. From they way it sounds you may want to do a teardown before any more damage is done if there is some kind of mechanical issue.
