Old 01-10-2011, 03:16 PM   #76
You CDI won't care. Go have fun.
Old 01-10-2011, 03:43 PM   #77
bi0phreak420   bi0phreak420 is offline
Awesome thanks doc
Old 01-10-2011, 04:43 PM   #78
Stock carb is back on and she is running like a top ...now let it snow let it snow
Old 01-10-2011, 08:34 PM   #79
mizke   mizke is offline
if she is running good with the stock carb back on, then run it for winter when the riding is limited. then once the weather gets within normal range throw the upgraded carb back on and start fresh..
but take your time making a plate to correct the carb alignment, get the right tools (harbor freight is now your best friend, "china tools for china bikes") and take youre time then when you finish you will have a nice cleanly made part. welcome to fabrication..
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain
Old 01-10-2011, 09:00 PM   #80
Thanks Mizke i have a harbor freight right down the street
Old 01-10-2011, 10:53 PM   #81
a metric tap & dye kit should be the first tool you buy, for mine for less then 20 bucks at hf. you can fix stripped out thread holes, bolt threads and if you drill a hole and need to thread it for a bolt you can do that to..
Old 01-13-2011, 10:07 PM   #82
anyone know where i can get some good tires
Old 01-13-2011, 10:34 PM   #83
um i run the exact same tire as the gbc ground buster.. its much wider then the stock rear tires.. but i love this tire, its got good all around bite even in light to moderate mud.. odds are i will always choose this tire when i need a new one.. but you should either get another set of rims for the front and rear and get winter/mud tires and then summer tires. or try and find a tire that will do a decent job in the weather conditions you ride in..
ok i run the gbc ground buster tire, size is 20x11.00-8.. there is a seller on ebay if you do a search for gbc ground buster 20x11.00-8. with shipping it comes to $65-$75 a tire
Old 02-02-2011, 06:10 PM   #84
MAN THE WEATHER IS BAD HERE WE GOT 2 INCHES OF ICE AND 3 INCHES OF SNOW....100,000 people with out power...come on spring!!!
Old 02-02-2011, 08:28 PM   #85
ya dude austin is getting the coldest weather in like 20 years.. wind chill of 0 tonight i think...i want it to ice over a little so i can go parking lot sledding with a 3600lb red mustang
Old 02-02-2011, 11:34 PM   #86
Jim   Jim is offline
Frozen parking lots sure can be fun can't they Everyone should practice in parking lots, I bet if everyone did they would be better prepared to handle their vehicle when road conditions aren't optimal.
"Be excellent to each other"
Old 02-02-2011, 11:59 PM   #87
IF we get any more snow this winter I like going nuts on the ATV. :P
The Vette will NOT see snow. I don't even take it out in the rain! :roll:
The pickup is 4WD, and I do practice controlling it in spins and slides and the like in untravelled areas if we get snow.
Old 02-03-2011, 12:09 AM   #88
Jim   Jim is offline
Yeah the corvette would probably not be a good one to practice with in the icy parking lots 8O
Old 02-03-2011, 12:14 AM   #89
Not for long.... :roll:
The 3 inches of ground clearance would be an issue, as also the 285mm wide summer tires, etc. etc. etc.
Old 02-05-2011, 10:27 AM   #90
FosterVS   FosterVS is offline
See my post about Homemade Traction. I was pondering getting some better tires, now I don't need to worry about it til spring.
