Old 04-17-2016, 12:40 PM   #91
muzo_31   muzo_31 is offline
Hi folks.
PCHUD archive links are broken today.
Can you please help ?
Old 04-17-2016, 01:44 PM   #92
Originally Posted by muzo_31 View Post
Hi folks.
If you can't download the files, I suggest you send a personal message to forum member Katflap.
Old 04-17-2016, 02:49 PM   #93
Thanks I'll do that.
cheers !
Old 04-20-2016, 05:22 PM   #94
No1Vic   No1Vic is offline
No1Vic's Avatar
Quick diy lead using http://www.ebay.com/itm/VAG-COM-KKL-...993964&vxp=mtr and modifying one of these http://www.ebay.com/itm/Extension-Co...466724&vxp=mtr works with PCHud
Plus you have the option to connect other OBD devices to the bike using the second modded lead :-)
2015 Honley RX3
2010 Suzuki 1250 Bandit
2006 Suzuki Hayabusa
Old 04-20-2016, 06:32 PM   #95
No1Vic's Avatar
Modded OBD lead to suit RX3 Port
This is the lead I have made to connect to the VAG KKL to USB adaptor for running PCHud on the laptop. Also I have been able to connect other scanners / adaptors to the bike using my lead :-)
2015 Honley RX3
Old 04-21-2016, 02:04 AM   #96
I have ordered similar cable to ebay: http://www.ebay.fr/itm/262367188038?...%3AMEBIDX%3AIT
Waiting for delivery to try this out !
Old 04-21-2016, 06:42 AM   #97
I have constructed a similar cable, but it failed to connect my MaxiScan MS309 to the Delphi ECU in my RX3.
Therefore, I reckoned the Delphi ECU software was not completely OBD2 compliant.
Have you had success reading a diagnostic trouble code (DTC) with another OBD2 compliant scanner? If so, please tell me which scanner(s) you have successfully connected to the Delphi ECU of the RX3. I have my cable handy, and I am eager to try another scanner.
If I can find an OBD2 scanner which will read and erase codes from the Delphi ECU, I will post a thread showing how to obtain the proper parts to fabricate the cable. Then everyone will have the option to carry a compact OBD2 scanner along with them when they depart on trips, et cetera.
Old 04-21-2016, 09:10 AM   #98
No1Vic's Avatar
OBD scanner I used is Innova 3110
Hi Spud, my scanner connected, detected the protocol and showed no DTCs present,
2015 Honley RX3
Old 04-21-2016, 10:56 AM   #99
No1Vic's Avatar
Hi Muzo, you will also need to make the OBD to RX3 cable as in my post #95 to connect the VAG KKL lead.
2015 Honley RX3
Old 04-21-2016, 12:20 PM   #100
My cheap scanner attempts to link with Keyword 2000, but doesn't connect with the Delphi ECU.
If you disconnect the O2 sensor, or disconnect the cable for the ignition coil, do you get the appropriate trouble code? Can you reconnect the cable, and clear the trouble code with the OBD2 scanner?
My MaxiScan MS309 scanner works with my automobile, but not my RX3. I'm pretty sure the Delphi ECUs in our CSC bikes have a different version of the software than the Honely bikes. Perhaps this is the problem?
http://www.autelscanner.com/products...MS309_749.html
Old 04-21-2016, 01:59 PM   #101
spud, i missed it if you said, did you verify your scanner is functioning on a automobile? very interesting hack .
i know network wiring is very temperamental from the little experience i have had with Ethernet cable transforming.
Old 04-21-2016, 09:56 PM   #102
Yes, my MaxiScan MS309 works with my automobile.
Old 04-24-2016, 10:48 AM   #103
No1Vic's Avatar
After trying what you suggested Spud it seems my scanner although shows connected it didn't pick up the DTC :-( Still shows no DTC's stored. PCHud did pick up error 49 so glad that works :-)
2015 Honley RX3
Old 04-24-2016, 11:12 AM   #104
Thanks for checking.
The PCHud software does work well. Apparently we need a Delphi Scan Tool, or its equivalent, to connect to the Delphi ECU via scanner.
Old 04-24-2016, 01:31 PM   #105
No1Vic's Avatar
OBD Protocol?
After looking more into PCHud I came across a presentation by John Boreham from Delphi where he mentions the protocol used by the software is ALDL, it's an OBD1 one originally used by General Motor so maybe the reason why our OBD2 scanners might detect but not be able to communicate with the ecu. Worth looking into further.
2015 Honley RX3
