07-22-2018, 08:31 PM | #1 |
Not that deep, but that air intake for the cooling is at the lower part of the engine and it just seems like it would plug up or ??? Not concerned about the actual engine air intake, just the cooling fan.
10-06-2018, 06:11 PM | #2 |
Exhaust leak at head
My bolts holding the exhaust on the head rattled loose and after tightening them it still leaks...anyone know what gasket is a good replacement?
10-11-2018, 10:45 AM | #3 |
Hmmm, I have the same as you and times wonder the point of water as well in the cooling fan.
Its also really low and not protected. |
10-11-2018, 12:21 PM | #4 |
studs
there should be studs in there.... you have to remove t he nuts.. then tighten the studs into the head so they are good and tight,,, then put the nuts on there,,, the heat will not let locktight would due to the high heat temp.. so made sure they are bottom out and tight,,, then you can put lock washers on or self locking nuts ... or double the nuts if you can get them on... you can always put longer studs so you can double nut it..
