Old 02-28-2018, 05:49 PM   #1
lildew   lildew is offline
vader motor swap
I wanted to do a quick write on a motor swap I saw online. I am not the first one to do this but just wanted to post a little info on this it is a zs190cc sold by pitster pro. engine mount bolt holes are a direct fit and the factory wiring from the CDI on the Vader will work you just have to match the same color of wires off the stator to plug from the CDI on the Vader there are 5 wires to hook up just match the colors. You do lose your gear selector on your speedometer when you do the motor swap, not a big deal the only wire that comes out of the gear selector is a neutral wire when you're in neutral on the motor it will show on the speedometer but nothing more than that. The motor does come with a carb oil cooler wiring harness and CDI. just thought I would share the info for anyone interested and doing this motor swap or want some more power to the vader!! I will post some pictures of the motor and bike for anyone you want to see what the fit looks like.
