07-03-2021, 04:09 PM | #1 |
Hawk DLX Fully charged battery- won't turn over?
Hey guys! My battery is fully charged, dash lights on, as soon as I press the ignition switch it sounds like the battery is dead click click click. Any help would be greatly appreciated!
07-03-2021, 06:07 PM | #2 |
I tested the solenoid thoroughly as well as the fuses. My multimeter reads 12 volts at the starter relay until I press the ignition button and then it drops immediately.
07-04-2021, 12:00 AM | #3 |
Does the engine turn over if you use the kick starter or is it seized?
07-04-2021, 08:18 AM | #4 |
A thought here, 12 volts the battery would be in a state of discharge. The voltage reading should be around 12.8 or better. Try putting it on the charger to see if it will take a charge or you will need to get a new battery.
