02-23-2021, 03:59 PM | #1 |
2019 BD125-15 not going into gear? Help!
I went riding and my bike no longer goes into gear.
I was cruising in 3rd gear and when I went to shift into 4th, it changed and engage and as I got on the throttle, it felt like it went into neutral. The bike didn't shut off and I was still able to cycle down to 3rd, 2nd, neutral, and 1st but it doesn't engage. The bike starts up and idles but it doesn't go into gear. I can move the gear shifter and I hear it click but it doesn't engage. Plus, I can't get into 4th gear at all. The gear indicator shows the goes going from 1st, to neutral, to 2nd, and to 3rd, but won't go into 4th. What can be wrong, please help me, I'm a newbie too. I hope I didn't mess anything up. Thanks in advance for your feedback. |
02-23-2021, 04:18 PM | #2 |
Did you check to see if the chain is still on the front sprocket or maybe the shaft or sprocket is stripped.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-23-2021 at 05:01 PM. |
02-23-2021, 04:35 PM | #3 | |
Wow, you are right on.....I didn't even think to check the chain. I just went outside to look and boom.....nothing was there. I just hope now that I didn't mess anything up. Do I have to drain the oil to remove the cover to change out put a new chain on? Thanks. |
02-23-2021, 05:03 PM | #4 |
No need to drain the oil. You will only need to remove the sprocket cover.
02-23-2021, 05:06 PM | #5 |
Here's a video that should help.
02-23-2021, 05:13 PM | #6 |
Isn't it nice when it turns out to be something simple and cheap to fix? Lol
02-23-2021, 07:05 PM | #7 | |
I hope that after I get the parts in that it will be able to go into 4th gear again too. Also, since I'm changing the chain, I'll do the 17T front sprocket too. |
