05-18-2011, 10:31 PM | #1 |
Qlink XF200 Battery Failure
Hey,
You guys jinxed the battery in my XF200 with all your battery troubles. I went to ride her because it was her turn in the rotation and she lite up the headlight for a second or two and then nothing. Would not crank a bit with the e start but no problem right? Wrong, I started her with the kick starter but she would just idle with a bad battery. Would not rev so could not be ridden. Anyway, I pulled the battery out and went to Batteries Plus to get a replacement but no dice. Out of twenty or so batteries none were the right size. Well I'll try WalMart before I hit the internet and got lucky with one that fit without the rubber boot. It was a tight fit but good to go. |
05-19-2011, 12:10 AM | #2 |
So far mine's been good!....but one never knows. I don't trust ANY stock batteries in ANY bikes I've ever owned.
Better go shopping at Walmart myself....just in case. If you locate one there Barnone, please post the part#!
05-19-2011, 12:13 AM | #3 |
The batteries are all old, and Chinese. :wink:
I ordered one for a DR200SE and it was perfect.
Happy to serve. |
05-19-2011, 01:39 AM | #4 |
I'm sorry to hear of your battery trouble, Vince. :? Although they are more expensive, the Shorai batteries are also an excellent choice; however, I think they might still be backordered. :roll:
05-19-2011, 01:50 AM | #5 |
I'm amazed that the batteries in our atv's (2007 and 2008) still work. The 200 really relies on a good battery, since there's no kick start.
05-19-2011, 01:54 AM | #6 |
My Zong came equipped with a new, Yuasa battery. I installed the battery acid as I assembled the bike, and the motorcycle started right up after I put some gasoline in the fuel tank. The Yuasa battery did an excellent job for several years before I needed to replace it with a Motocross/Yuasa YTZ7S battery.
05-19-2011, 06:43 AM | #7 | |
The battery that I bought at Walmart and installed in my Qlink XF200 is a Everstart ES9BS sealed battery for $45.00 plus tax. It is a tight fit. It is made in China. The battery in my 2005 Yamaha XT225 that I have had since almost new is still original. The bike has been sitting in NC for the winter for the last two years with no charger on it and she fires right up. Don't know what brand since I have never had it out of the bike. Surprised that no one mentioned my experience with the kick starter. Started with the dead battery but she did not not rev up so the Q was not ridable! |
05-19-2011, 07:25 AM | #8 | |
Once it is running, the alternator or magneto or whatever it has should provide enough juice to keep it running, otherwise you would always be draining the battery. Any thoughts on why it wouldn't run? Does the battery act as a voltage sink and regulator?
2008 Yamaha WR250x 2006 Honda CRF250R Sold: 2002 Suzuki SV650S, 2009 Qlink XF200 |
05-19-2011, 10:04 AM | #9 |
You need a healthy battery to run a modern street bike, because the magneto can't provide enough power for spark and the always-on headlight. On my atv, I can run with a virtually dead battery, because I can switch the headlight off.
Many years ago, I had an XS650 Special, and I couldn't even kickstart it if the battery was dead. It needed close to nominal voltage in order to start. I regard the kickstart to be a backup in case the solenoid or starter fails, not in case the battery dies.
05-19-2011, 11:55 AM | #10 | |
Happy to serve. |
05-19-2011, 11:55 AM | #11 |
Betcha it's a Yuasa. Made in USA. 8)
Happy to serve. |
05-19-2011, 01:34 PM | #12 |
dont see why it wouldn't rev, if it will start with the kick it should run. usually its fuel injection that has that type of issue. on my lifan and xr motors the battery and ignition circuits do not rely on each other.
05-19-2011, 03:33 PM | #13 |
I don't know why it would not rev either. Idled just fine but give it the gas and it would bog and die. Puzzling.
05-19-2011, 04:05 PM | #14 | |
05-20-2011, 12:49 PM | #15 | |
