02-11-2017, 08:12 AM | #1 |
Tire changing isn't all fun and games.
Besides tire irons, and lube, you might need rim protectors, and a wire gadget to pull the tire valve through the hole in the rim, and a method of "breaking" the bead. And then there is the possibility of "pinching" a tube, and you need to start over. It can be very frustrating. There used to be a shop in north GA that would mount and balance a new tire, off the bike, for $15....not any more. If I could get it done for that now, I would. If you think you will be motorcycling long term, you might want to buy a tire changing machine. You can buy one on your own or go in together with some riding buddies. Some local riding groups have a tire machine for the group. Or ask around and you may find someone that has a tire machine that will mount a tire for a six pack of his favorite brew. This one has has paid for itself over the years. However, since I don't have a permanent place to set it up, I find that I regularly pull out the tire irons, instead. jb
02-11-2017, 04:56 PM | #2 | |
I use a old 14' alloy car rim with a bit of hose split & glues on the rim edge to protect the wheel.. ..
02-11-2017, 05:03 PM | #3 | |
Metal plate you can weld some studs on or just drill & tap some holes. A 3'x3' sheet of 3/4" plywood with either Tee nuts installed or some carriage bolts driven through will also suffice. When not in use, disassemble & tuck them all away. Or if you plan ahead the same base can be used to mount a pedestal grinder, vise, or other shop thingy. Jay, cheap-ass bastage. |
02-14-2017, 09:59 PM | #4 | |
Since then, I've bolted the changer to a piece of 3/4" plywood with carriage bolts, and the changer is in NC. The problem is that I only change 3 or 4 tires per year. The changer is stored under the basement stairs, and invariably gets buried under piles of "stuff" before I need it again. jb
