11-19-2017, 01:57 PM | #1 |
Hawk leak
So this morning I woke up to a oil leak under my bike. Can anyone tell me why this is leaking and if I can fix it. Thanks
11-19-2017, 02:51 PM | #2 |
Looks like a head gasket seeping oil.
2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2010 VFR1200F - http://chinariders.net/showthread.php?t=20708 |
11-19-2017, 04:54 PM | #3 |
That or one of the O-rings that seals the oil passage between the head and cylinder has went bad.
11-19-2017, 06:12 PM | #4 |
Head gasket
11-19-2017, 09:48 PM | #7 |
Head bolt torque is 29lb-ft. If you remove the head, retorque in at least 2 stages in a criss.cross pattern.
12-11-2017, 07:38 PM | #8 |
So i got my new gaskets in today. How hard is it to change them out?
12-11-2017, 08:05 PM | #9 |
Not hard, just don't drop your pushrods down inside LOL!
12-25-2017, 06:39 PM | #10 |
So I tourqed it at 29 ft lb and it still seems loose is this correct
12-26-2017, 04:06 AM | #11 |
No, it is not correct. It sounds like something wasn't seated properly.
12-27-2017, 08:34 PM | #13 |
After a couple of full heat cycles or say 100 miles of riding, it would be a good idea to go back and check those head bolts one more time.
01-06-2018, 01:32 PM | #14 |
What size is the pilot/slow jet in that carb?
01-06-2018, 01:47 PM | #15 |
Not sure,whatever comes stock on the hawk. Just got back now and it seems to ride fine besides a burple sound when I release throttle while moving. Is this normal should I go back to 115?
