Old 11-19-2017, 01:57 PM   #1
Lit Hawk   Lit Hawk is offline
Lit Hawk's Avatar
Hawk leak
So this morning I woke up to a oil leak under my bike. Can anyone tell me why this is leaking and if I can fix it. Thanks
Old 11-19-2017, 02:51 PM   #2
Looks like a head gasket seeping oil.
2010 VFR1200F - http://chinariders.net/showthread.php?t=20708
Old 11-19-2017, 04:54 PM   #3
ben2go   ben2go is offline
That or one of the O-rings that seals the oil passage between the head and cylinder has went bad.
Old 11-19-2017, 06:12 PM   #4
silva   silva is offline
silva's Avatar
Head gasket
https://www.ebay.com/itm/222260062961
Old 11-19-2017, 06:49 PM   #5
Lit Hawk's Avatar
Awesome. Thanks for the help
Old 11-19-2017, 09:05 PM   #6
JeremyC   JeremyC is offline
That one looks a bit further gone than mine did, but you might consider attempting a retorque of the head bolts. It may stop. I caught mine at the first signs of an oil film.
Old 11-19-2017, 09:48 PM   #7
Head bolt torque is 29lb-ft. If you remove the head, retorque in at least 2 stages in a criss.cross pattern.
Old 12-11-2017, 07:38 PM   #8
Lit Hawk's Avatar
So i got my new gaskets in today. How hard is it to change them out?
Old 12-11-2017, 08:05 PM   #9
Not hard, just don't drop your pushrods down inside LOL!
Old 12-25-2017, 06:39 PM   #10
Lit Hawk's Avatar
So I tourqed it at 29 ft lb and it still seems loose is this correct
Old 12-26-2017, 04:06 AM   #11
No, it is not correct. It sounds like something wasn't seated properly.
Old 12-27-2017, 07:38 PM   #12
Lit Hawk's Avatar
Finally got to test it out and no leak so far everything looks good. I think that torque wrench was just so easy to turn the bolts they felt like they weren’t tight at all.
Old 12-27-2017, 08:34 PM   #13
After a couple of full heat cycles or say 100 miles of riding, it would be a good idea to go back and check those head bolts one more time.
Old 01-01-2018, 01:54 PM   #14
Lit Hawk's Avatar
So I took the hawk out riding Saturday and now I have to turn the throttle up to get it to start way more than usual. When it starts to warm up it’ll idle way to high I’ll have to adjust but it then acts like it’s going to die, almost like somethings sticking. It rides fine it’s jyst when I come to a stop it’s idling high then slowly starts dropping till I have to give it throttle. I’m not sure if it’s because I didn’t adjust my valves correctly I set them at .002,.003. I tried adjusting the carb but it’s the same. Any suggestions?
Old 01-01-2018, 10:00 PM   #15
Suggestions.
Don't adjust the base idle speed. Once the bike is nice and hot, say after 10 minutes of riding, set the idle to 1500rpm and don't mess with it unless your idle speed once warmed up has changed due to air temps. Get used to the idea of "nursing" the throttle to keep it idling until the bike is up to temp.
You aren't mentioning if you are using the choke when trying to start or not, so that leaves an unknown variable.
Usually a racing idle as you describe is caused by a lean condition on the pilot/mixture circuit. This style of carb doesn't adjust for air density like a CV carburetor, so as the temps outside swing up and down the AFR also changes with them. If your pilot or idle mixture were just a hair lean during warmer temps, then they can start to be too lean with a big enough difference in air temp.
So before I suggest too much, can you describe if you are using the choke on these cold starts? That will really determine the direction I go with more suggestions.
