07-14-2016, 10:45 PM | #1 |
Hawk turn signal alarm
Is there a link on how to disable the alarm? I turned the ignition switch on in my shop and the turn signal was on. My dog and I have trust issues now.
07-14-2016, 10:48 PM | #2 |
If you look at the bottom of the blinker module(under the seat) I believe you should see an opening at the bootm. If you stuff some paper towel in there it will muffle it. If you are ok with making a permanent change you can take it apart and clip the wires for the speaker. I was amazed at how tiny the speaker is yet it makes such a loud noise.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust. |
07-15-2016, 12:05 AM | #3 |
I found the flasher and unplugged it. No turn signals and no alarm now. The flasher box is sealed but does have some movement were the connections go into the box.
07-15-2016, 12:13 AM | #4 | |
The cover will pop right off. Not sealed tight..... |
07-15-2016, 12:37 AM | #6 |
I used a couple of small precision screwdrivers to pop the end of the box off. That speaker is tiny but it has a big bark.
2015 and 3/4 RPS Hawk 250. Most people would call it a 2016 but the MCO didn't. Last edited by hertz9753; 07-15-2016 at 12:39 AM. Reason: adding picture |
07-15-2016, 01:26 AM | #7 |
SpudRider, pls include this topic in FAQ
Old thread: http://chinariders.net/showthread.php?t=16442
07-15-2016, 01:29 AM | #8 |
I snipped the wires and pushed on the speaker with my finger and it came loose. I don't need an alarm when I have four lights in front of me that I can see on the Hawk.
07-15-2016, 11:51 AM | #9 | |
06-12-2018, 11:33 PM | #10 |
What is the speaker for
06-13-2018, 07:39 AM | #11 |
That was the first thing i did to my hawk. snip that wire!!!!!!!!
06-13-2018, 11:14 AM | #12 |
It beeps in time with the signals, so you can hear that the signals need to be switched off.
