07-03-2017, 07:00 PM | #1 |
Opinions on Mikuni TM
What do you guys think of this carb? I heard good review about it, TM series is supposedly better than the VM series.
http://www.mikunipower.com/tm01.htm http://www.sportrider.com/mikuni-tm-...ce-carburetors |
07-03-2017, 07:59 PM | #2 |
TM carbs are great carbs. I had 4 on a CB750 a few years ago. If you are chasing perormance then these or a PWK flat slide are the way to go. I am doing a 30mm pwk on my Hawk. I just got the intske boot for it to mount to the head.
07-03-2017, 09:44 PM | #3 | |
The TM series Mikuni's have a very real advantage over most other flat slides. Interchangeable slides. Slide cut-away controls low end acceleration. Less cut-away gives a richer mixture when cracking open the throttle. More cut-away makes it leaner. On many other flat slide carbs, you change carb bodies to richen or lean out that surge of fuel when cracking the trottle....ARH |
