02-20-2019, 07:03 PM | #1 |
2019 New Hawk 250cc enduro, needs performance upgrades.
I found the Fuel / Air mixture screw after I extracted the rubber plug.
Remove the Carborator to do this, my bike would not run or idle. I shimmed the needle jet with a small washer. I need to find jets for my Carborator? The Stock gearing SUCKS, I need info on regearing. Removed the baffle, just behind the 3 screws, but the stock exhaust sucks big time no flow at all. Hawk 250cc enduro needs help asap!!! |
03-12-2019, 08:08 AM | #2 | |
have you set your Valve lash? also i would not mess with the stock carb.. too much hassle when a 'mikuni' is only 30 bucks plus 5 dollar jet kit. check out motocheez on youtube and do a few searches on the forum. |
03-12-2019, 08:16 AM | #3 |
Welcome aboard! You can find all this information in one spot. Check out the Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331
03-12-2019, 04:05 PM | #4 | |
