11-19-2020, 12:40 AM | #1 | |
Even when Honda, Yamaha, suzuki, Kawasaki use these this type of headlight assembly they use 35/35 w bulbs. |
11-19-2020, 09:06 AM | #2 | |
11-19-2020, 09:26 AM | #3 |
Get a good LED bulb. It will be brighter and put out way less heat than a standard bulb.
11-19-2020, 09:31 AM | #4 |
Indeed for these headlight housing is the ideal. Because 35/35 is just way too weak and using 50/65 either you melt the housing or the wiring will give up.
11-19-2020, 11:42 AM | #5 | ||
Jerry - I like the fit of the led bulb type you recommended. It is more true to form with the conventional bulbs form and size and more likely to fit in the confined space. It may not matter however but I opted for the 30 Watt version of the same make as yours to be on the safe side. I figure 30 watts from an LED Bulb will be roughly 8 times brighter than a comparable halogen bulb. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Again thanks to both of you. |
11-19-2020, 09:42 AM | #6 | |
Looking for New LED 9003 Bulb
I am also concerned about size of bulb. There is very little "behind the headlight" room. Here is one that is listed as 35 Watts however size behind the bulb is a concern: https://www.amazon.com/H4-9003-HB2-S...NsaWNrPXRydWU= Thank you! |
11-19-2020, 09:48 AM | #7 | |
