Old 04-11-2013, 08:38 PM   #1
craig1979   craig1979 is offline
Help with 2006 zongshen storm 250cc gs
Bought a zongshen storm.. Put a battery in and away I rode
After 3 days was riding and the bike shut off.. Started again then got it home.. Replaced the spark plug, coil and lead then it rode fine for a few more days then did it again.. Bike started again after a hour so o rode it home, waited a day to try it and it started first go
Anyone have a idea what is wrong
Old 04-11-2013, 11:08 PM   #2
CDI would be my guess. They're cheap, so buy a couple.
Old 04-11-2013, 11:33 PM   #3
Living in Australia it's a bit harder to get hold of a cdi
Is the cdi known for working then not working
Old 04-12-2013, 07:19 AM   #4
katoranger's Avatar
It does sound a CDI failure. Yes they are known to fail also.
Old 04-12-2013, 07:22 AM   #5
will try and get my hands on a new one
if its not the cdi where should i look next
Old 04-12-2013, 08:05 AM   #6
humanbeing's Avatar
AC or DC CDi?
http://www.chinariders.net/modules.p...wtopic&t=14222
Old 04-12-2013, 08:16 AM   #7
not sure lol
Old 04-12-2013, 10:41 AM   #8
Originally Posted by humanbeing
Humanbeing, is that CDI specific to the Yamaha / Zong 200? Is there a version for the CG200? Also the OHC Honda 200 clone? I tried to read the success story, but Google translate is not good enough.
Old 04-12-2013, 11:37 AM   #9
humanbeing's Avatar
This http://item.taobao.com/item.htm?id=3289740994 had English version. 1/3 of their customer is outside PRC. Simple written English is quite OK for that developer.
That developer's warning: some new model's pinout isn't as the "generic", you MUST know which wire = which function, otherwise ... http://www.motoyes.net/bbs/thread-534491-1-1.html
Old 04-13-2013, 01:19 AM   #10
going by the picture of the plug you put up and using a test light while trying to start i get the following
1 - black/yellow - nothing
2 - green - nothing
3 - green - nothing
4 - blue/yellow - flashes
5 - empty
6 - white/black
7 - black/red - constant
8 - empty
Old 04-14-2013, 04:56 AM   #11
I also suspect the CDI unit is failing. All of the Chinese CDI units are poorly manufactured. :roll: The CDI units usually exhibit intermittent failure for a few weeks before they die completely. I suggest you order several spare CDI units from Taobao.
http://item.taobao.com/item.htm?spm=...&id=4423465878
Old 04-14-2013, 05:40 AM   #12
even translating that site to english is was tuff to read lol.. need to work out the price difference
Old 04-14-2013, 11:38 AM   #13
The folks at www.tbtrends.com can help you with that. Just paste the link of the Taobao item you want into a tbtrends order form, and they'll take care of you.
Old 04-15-2013, 05:00 AM   #14
cheers will check them out
Old 04-15-2013, 08:27 AM   #15
Just ordered one.. will let you guys know if that was the problem
cheers to all that helped
