04-19-2019, 11:01 AM | #1 |
First Rhino Issue
Well, the ignition switch has got funky on me. I have to jiggle the heck out of it to get the neutral light to pop on and get battery juice. I think I'll upgrade to a toggle switch from the hardware store.
04-19-2019, 05:24 PM | #2 |
I had a problem with my cutoff/start switch. Had to take it all apart and soak some WD40 in there.
It's stored outside so it doesn't help that situation. Just use a tarp to cover it. |
04-19-2019, 06:58 PM | #3 |
À good double pole weatherproof toggle is a good idea. EBay has new OEM key switches for under $5.
04-22-2019, 11:17 AM | #4 | |
https://www.amazon.com/Wire-Ignition...27730306&psc=1
05-07-2019, 11:13 AM | #6 |
Ok, I got the ignition switch fixed. Just a disassembly and cleanup did the trick.
Suddenly, after it kicked and farted a few times, no spark. Tried a spare CDI, nothing. I think I've been "mouse chewed" somewhere. Time to wheel it to the garage and get serious.
