03-23-2018, 09:01 PM | #1 |
Changed your fork oil lately?
I am sure there are a few people on here that think my maintenance schedule is ridiculous. Sure, maybe it is, but I figured I would use this as an example of why.
This is the fork oil I put in my Hawk last year during assembly. It started off a light green color. Now it's full of dirt and particulates. New fresh Spectro 15w added after flushing them with MMO and letting them hang inverted for half an hour and they are much smoother. 10 bucks in fluid and taking a front wheel off to remove 2 forks by undoing 6 bolts means longer seal and bushing life. Oh, and my silly habit of checking my valve lash during oil changes? Intake was at .0055" after just 400 miles.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 03-24-2018 at 05:26 AM. |
03-25-2018, 07:45 PM | #2 | |
03-25-2018, 08:03 PM | #3 |
My seal started leaking a couple days ago. Searched on here and found out I can clean it with a business card and re seat it. Hopefully it fixed the problem, I should know in a couple days if it did or not. I really need to change my oil out but when i first got my bike I put new oil in and it seemed like the bolt on the bottom of my fork stripped. I don’t think it did because other people have this problem fixed with a broom handle. I just haven’t done it yet and it didn’t leak. So I let it be. It always makes me nervous messing with this bike and making it worse than it was. Especially with stripping the bolts.
03-25-2018, 08:47 PM | #4 | |
I take off the front wheel and caliper, then undo the top clamp pinch bolts, loosen the fork cap, and then undo the 2 lower pinch bolts. Take the fork out, remove the cap, remove the spring, then invert and pump a few times and then set them upside down for a few minutes. Fill, reverse removal process
03-25-2018, 08:49 PM | #5 | |
03-25-2018, 10:05 PM | #6 |
Not sure how to do the quote in comments beside copy and paste but I doubt that’s right. Anyways awesome megadan I followed a tutorial somewhere on this site and it drained through the bottom. I like your way a lot better and will be doing it next weekend. I wanted to do it today but like I said scared to mess with that bottom screw And making things worse. Also messing with the start button, leaky fork seal which Looks like it fixed, and my underglow lights took up most of my day(pinched wire was grounding lights on and I made things way worse by trying to work on it without disconnecting negative from battery I melted wires, luckily I fixed it) . Now that I know I don’t have to touch bottom bolt for changing fork oil, awesome. Thanks
03-25-2018, 11:14 PM | #7 |
Unless the forks have a specific drain plug, that bottom bolt shouldnt be touced except for actual dampening rod removal. I wish that method would die off. The proper way is as I described to you. Plus, it is a great opportunity to check the wheel bearings and brake pads for wear.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 03-26-2018 at 12:25 AM. |
03-27-2018, 02:45 PM | #8 |
whats MMO? thanks Rob
Live Zong, and Prosper |
03-27-2018, 03:10 PM | #9 |
03-27-2018, 05:03 PM | #10 |
I made one from a plastic 2 liter coke bottle. I had one leaking Saturday and cleaned it. All good I had the one on the opposite side leak a few months back and did the same. I keep it in my tool tube incase it starts leaking while offroad.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-28-2018 at 06:36 AM. |
03-27-2018, 07:38 PM | #11 |
That’s a good idea, I’ll have to make one also to keep on my bike. I used a business card To clean mine and it’s been 2 days with no new leak
03-29-2018, 07:48 PM | #12 | |
04-16-2018, 09:41 AM | #13 |
How much for oil goes back in them?
04-16-2018, 09:54 AM | #14 |
04-16-2018, 02:56 PM | #15 |
You can use as little as 160-170ml, But 210ml is the recommended level. I ran as much as 230ml to increase the air spring effect.
