12-07-2016, 09:00 AM | #1 |
more carb talk hawk 250
Ok so when I ordered my hawk 250 I ordered a carb also ... Like the rest of us I thought I was ordering a 30mm carb but I was wrong ... Its like the same one you can buy on hawk250.com
First looking at the VM28 flatside or TM28 flatside there both pretty pricey but then I found the PWK28 flatside.. I think I might order it this week and see what I can gain with it if anything.. and the intake seems bigger then the vm26 round style we been using also so probably have to mod the air intake tube ... Anyone running a PWK28 ? And I see its been asked but Is anyone running a VM28 or TM28 ? |
12-07-2016, 11:58 AM | #2 | |
12-07-2016, 03:30 PM | #4 | |
12-07-2016, 06:56 PM | #5 |
Hey, I one hundred percent agree with you - but I'm always willing to learn something new. I was hoping he'd tell me what the advantages of a 30mm venturi carb would be on this bike.
12-07-2016, 10:44 PM | #6 |
Me too, especially when it's someone else's money.
12-08-2016, 12:19 AM | #7 | |
12-08-2016, 10:14 AM | #8 |
The intake manifold for the CG motor has a rubber hunk between two metal flanges for the head and carb. It's supposed to be for heat or vibration or something, not sure what if not both. After a few years, the rubber (awesome China quality) will start to break down and crack, creating a real lean condition. You'll wonder why your perfectly good bike's not running right.
I did a write-up on it here. http://www.chinariders.net/showthrea...ghlight=intake
12-08-2016, 10:49 AM | #9 | |
12-08-2016, 01:11 PM | #10 | |
12-09-2016, 09:05 AM | #11 |
My main issues is I ordered the wrong carb ...
Thought I was getting a 30mm carb and I guess the inlet is but not the inside.. Were all pretty much running 26mm carb's and none performance ones too boot The VM28 flatslide carbs are like 80-110 bucks plus you need to get a new boot to connect it too the motor ... The flatslide carbs are supposed to have better throttle response also Are bikes should gain from 26 too 28 inside Thats where the pwk28 comes into play and seems like a good deal http://www.ebay.com/itm/112023070837 29.99 and free shipping ... It's worth a shot to me .. I will try it sooner or later and yes I have the full exhaust and air box mod. |
12-09-2016, 10:29 AM | #12 | |
12-09-2016, 01:48 PM | #13 | |
12-09-2016, 03:02 PM | #14 |
I dont think going from a 26mm too a 28mm is going to make you lose bottom end ... It might get harder to tune but it should be the same or more.. Specially when your switching over too a performance carb
I looked into other areas and it seems tons of people run 28mm carbs on 120-140cc bikes .. Are motors are nothing fancy but they are 229cc's and should utilize a 28mm carb |
12-09-2016, 03:04 PM | #15 |
O and don't forget there's 2 styles of the VM carbs .. the round style and the flat style..
The round has a butterfly choke and round slide <-- none performance The flat has a starting circuit and a flat slide <-- performance I have a round vm26 round so when I do this if i don't see a gain then I can tell everyone its not worth it lol |
