07-22-2019, 09:59 AM | #1 | |
Like Dan stated. The center stand makes the oil change much easier. Bike is level and no jack stuck in the way of the oil drain pan. With the oil cooler the life span is much longer between oil changes. Before the oil cooler @ 500 miles the oil would be almost jet black. After installing the oil cooler I changed the oil at 1000 miles and still be a nice golden brown. So the next oil change I pushed it to 1200 miles. Still same golden brown. Now I know this will make Dan and a few others cringe but I have about 1500 miles on the oil and is still a golden brown but I am scheduling an oil change soon even though it probably doesn't need one. Since I installed the dual coolers my oil temps have never gone over 200*. Highest I seen was 189*. This was on a 98* day with the heat index of 106*. Yeah, too dang hot to ride. I do use Quicksilver 15W50 full synthetic Motorcycle oil so not to worried about oil break down. My thinking is if my full size truck is designed for 9000 to 10000 mile oil change intervals I'm sure the little china bike engine will be okay if I push it to 2000 miles.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-22-2019 at 11:31 AM. |
07-22-2019, 12:23 PM | #2 |
By what means are you getting the oil temps?
07-22-2019, 01:30 PM | #3 |
From this temperature/volt meter I installed. Link to thread. http://www.chinariders.net/showthread.php?t=22409
07-22-2019, 04:14 PM | #4 | |
The 1500 mile interval doesn't make me cringe at all. I use shorter intervals because how my bike is used is pretty rough on the oil. Short trips mixed with lots of hard highway runs. I destroy the oil pretty quick. I expect this 15w40 T6 to last every bit of 1000 miles, and possibly longer.
07-22-2019, 04:17 PM | #5 |
I always warm he engine up before changing the oil. I just forgot to mention that. lol
07-22-2019, 05:04 PM | #6 |
I figured, and I normally do as well. My one exception is if the bike has been sitting for a couple of days. By that point most of the oil has drained down to the sump.
