05-24-2021, 10:01 AM | #1 |
So I clicked the key on and off 3 times to get the code 0562 which corresponds to "EFI system voltage too low". So overnight I charged the battery and it cranked first try this morning. The check engine light is still on though so I'm worried the problem is still around.
05-24-2021, 10:36 AM | #2 | |
05-24-2021, 07:21 PM | #3 |
Okay thank you I will do this. It would certainly explain all my symptoms.
