04-22-2017, 08:20 PM | #1 |
brozz speedo not registering speed
took it out for a short trip today and the speedo comes on and goes to zero like usual but doesn't register any speed? it was working fine last weekend and i haven't done any work on it ..just parked it. any ideas what i should check before i pull it apart?
04-22-2017, 08:50 PM | #2 |
Did you loctite the connection on the cable down by the wheel? It could have backed out a little, just enough to have the metal pin part in the cable not to catch and register... If that makes sense.
04-22-2017, 09:02 PM | #3 |
i didn't, thanks i will check that for sure!
04-22-2017, 09:11 PM | #4 |
ok...i'm an idiot! pulled the headlight assembly off and it was just unplugged..must have not been fully seated and vibrated loose. K.I.S.S...always!
04-22-2017, 09:31 PM | #5 |
Been there
Headlight plug
