08-22-2016, 01:15 PM | #1 |
Remember,
On the fuel pump there are 3 ports. - A fuel in - A fuel out - A vacuum port for the diaphragm If you look on the back of the pump closely you will usually see stamped arrows showing the fuel flow intended direction. |
08-22-2016, 01:17 PM | #2 |
This diagram uses the EXACTO carburetor.
Pep cock and fuel tanks may vary. |
10-23-2016, 04:42 PM | #3 |
Just wanted to thank everyone who posted. Sorry I hadn't responded as of late. Been busy with work, but the bike is up and running. Got the fuel lines figured out, thanks to that awesome diagram.
Now I'm just working on piecing the outer bits together. Pity the manual doesn't show anything on the air filter system rofl |
fuel hose, vento |
