12-09-2016, 04:23 PM | #16 | |
Which one is close?
12-09-2016, 05:07 PM | #17 | |
12-09-2016, 08:00 PM | #18 | |
I know there was some concern about the carb not being rubber mounted, etc...but I had it on my Xmoto for a year or better without mishap or vapor lock or whatever else. My air cleaner pod hung off the back of the carb unsupported, so it actually had better support with the solid manifold. Again, so far I've had no issues. I'll be interested to hear other reviews.
12-09-2016, 08:16 PM | #19 |
I use these on my bikes ..
flat slide , smooth bore , power jet carb.. 32mm on my TTR250 / 26mm on 77 Montesa Cota 348 trials bike. the boys CRF150 will get a 28mm when I rebuild the motor.. main & pilot jets are like 10 for $10.. I have all mains from 90 to 200 / all pilots from 20 to 80 & 3 diffrent needle tappers... And they are the same prise as some of the rubbish you fellas rave about... just look at the pics... totaly smooth polished bore with no lumps in the intake to stuff up the air flow / ventury effect... these little buggers work & work bloody well.. https://www.aliexpress.com/item-img/...00017.2.TqrCNs https://www.aliexpress.com/item/PWK-...608.0.0.SoaO7i ..
12-09-2016, 11:35 PM | #20 | |
12-10-2016, 08:31 AM | #21 |
Thats the carb I posted and have been talking about in this post -_- .. reason i made the post .....
12-11-2016, 09:26 AM | #22 |
Well... found a few places selling inexpensive Keihin, OKO, and KOSO brand "Power Jet" carbs... going to order a 32 or 34mm flat-slide with power jet and see just how much we are missing out on compared to the VM26 clone that is currently on the bike...
If anything it's another $30 experiment... and from the sounds of a few around here... who knows... I might be able to no clutch wheelie the gutless bike through 4th gear with all the Power I will get from the new carb ... or I will end up losing my 100+ miles per gallon range... Or I might end up trading the low end Torque for high end HP with the bigger carb... might end up increasing power/torque across the entire RPM range... we'll find out soon enough I guess According to the company I'm going to order the carb from they recommend using no less than a 32mm carb for anything over 175cc (and I've been using a 26mm carb on a ~200cc engine)... I currently have a ~197cc Lifan Engine (push valve) and one day I will upgrade to a 223+cc Zong/Honda Engine (OHC)
12-11-2016, 11:22 AM | #23 | |
12-11-2016, 03:53 PM | #24 |
NO GUTS NO GLORY, RIGHT? In this case, no cash, no play.
12-11-2016, 04:23 PM | #25 |
DO IT UP or at least ill wait for you ... I was just going too the 28mm because 26mm / the vm26 round slide carb hasss to be holding the motor back some ...
Plus when you have the flat slide/performance carb it shoots fuel when you snap the throttle and that gives you a more responsive throttle .. that should aid in doing wheelies |
12-11-2016, 09:02 PM | #26 |
Popping wheelies up to 4th gear...
12-11-2016, 10:43 PM | #27 | |
12-12-2016, 10:07 AM | #30 |
Keep a couple things in mind on these carb choices.
1- You're only dealing with the mighty fire breather of a low compression, pushrod, glorified 200cc motor. 2- I've over-carburated a few vehicles in my day and they were nothing but poor running nightmares that were impossible to start. Not enough venture action, not enough atomization. Soggy plugs. When it comes to fuel delivery, more and bigger is not always better. I'll be curious to see how the other carbs work out.
