Old 05-05-2015, 06:22 PM   #11
Originally Posted by Weldangrind View Post
Not for long. The chamber has such low volume that you'll expel most of it by just checking the pressure.
Originally Posted by SpudRider View Post
Yes, if the shock contains nitrogen, I realize by merely checking the gas pressure, I will also need to arrange for one of the local shops to recharge the nitrogen. However, the QLink XP200 had a shock which set the preload with a low pressure of air. I need to call CSC, and verify the design of the shock absorber for the Zongshen RX3.
I called CSC this morning, and got some information regarding the shock absorber. Indeed, the shock does contain nitrogen, and the pressure of the gas might be as high as 320-375 psi. I'm sure if the nitrogen pressure were low, my shock would not be functioning as well as it is.
I am on the hunt for an aftermarket shock absorber. Is anyone else interested in upgrading the stock shock absorber?
