Old 01-11-2013, 01:29 AM   #1
New Shineray X5 has Copy of XR400R Engine
The new Shineray X5, dual sport motorcycle is in production. This bike employs a fairly close copy of the Honda XR400R engine. Here are links to several, interesting threads.
http://shinerayforum.com/index.php?topic=730.0
http://www.mychinamoto.com/forums/sh...y-X5-is-coming
http://www.mychinamoto.com/forums/showthread.php?4833
Finally, the Chinese are manufacturing a copy of the air cooled, XR400R engine, with an electric starter! Here's a photograph of the left side of a Honda XR400R engine.
Here's a photograph of the left side of the Shineray X5 engine.
Old 01-11-2013, 02:01 AM   #2
Here are a few more photographs of the Shineray X5.
It's nice to see new Chinese bikes, with larger displacement engines. However, I wonder if this bike will ever pass EPA mandates, let alone get imported to the United States at a reasonable price. :roll:
Old 01-11-2013, 02:12 AM   #3
Here is a photograph showing both sides of the Shineray, 400cc engine.
Here are some photographs of the Honda XR400R engine.
Old 01-11-2013, 02:16 AM   #4
Wild_Alaskan's Avatar
I want a commission on this model :P
Old 01-11-2013, 02:18 AM   #5
Contact Shineray, and good luck!
Old 01-11-2013, 02:26 AM   #6
I do like the kick start and e-start. I only had e-start on mine with the 400ex motor
Old 01-11-2013, 02:31 AM   #7
Here's a link to the engine being sold on Alibaba.
http://www.alibaba.com/product-gs/65...il_cooled.html
Old 01-11-2013, 02:36 AM   #8
Here's a link to the Shineray X5 being sold on Taobao. The price is 25,800 Chinese yuan, which is currently exchanged as $4,151, before shipping.
http://item.taobao.com/item.htm?spm=...id=19674456938
Old 01-11-2013, 03:22 AM   #9
It appears the Shineray engine has a manual decompression lever on the right exhaust valve, just like the XR400R engine. Here's the Shineray engine.
Here's the XR400R engine.
Old 01-11-2013, 03:41 AM   #10
The major difference between the Shineray and Honda engines is the location of the clutch lever on the right crankcase cover. The Shineray engine places the clutch lever approximately 90 degrees counterclockwise from the Honda location. Perhaps the clutch lever was moved to provide clearance from the large electric starter. Also, the Shineray engine does not have a separate cover for the clutch plates; therefore, you would need to remove the entire right crankcase cover to service the clutch. However, I need to do the same thing to service the clutch on my Honda XR650L.
The Shineray X5 might lack an oil reservoir in the engine frame and downtube. If this is the case, the Shineray might store the engine oil in its large, well protected, external oil cooler, which is placed high on the downtube.
This appears to be a well manufactured motorcycle.
Old 01-11-2013, 03:52 AM   #11
It appears that most parts of these two engines would be identical, excluding the crankcase covers, et cetera. The Shineray engine appears to be very robust and a reasonable copy of the Honda engine. I much prefer the simplicity of this air cooled engine to the other, Chinese, water cooled engines.
The Shineray X5 also has an adjustable shock absorber, with an external oil reservoir.
Old 01-11-2013, 04:14 AM   #12
The cylinder bore and stroke are identical between these two engines. Engine displacement and compression are also identical. Both engines also share a 5-speed transmission. Since both engines employ a 4 valve, RFVC (Radial Four Valve Combustion) design, I must assume the Shineray engine is a very faithful copy of the Honda engine, except for the minor differences I mentioned earlier.
Looking at the engine mounting points, I assume the Shineray engine would mount perfectly in the Honda XR400R frame.
Old 01-11-2013, 10:35 AM   #13
That looks like an NX400 engine.
Old 01-11-2013, 10:35 AM   #14
Or an XR250R frame.
Old 01-11-2013, 10:39 AM   #15
The NX400 design explains the clutch placement.
