03-24-2016, 11:05 PM | #1 |
Hondoid CG Motor Intake Fix
Common knowledge, Chinese rubber that comes on some of these bikes is marginal, at best....and I'm being nice. It's also known that the rubber embedded intakes on these will fail from time and heat. They start to micro crack in a bunch of places and then all it takes is a little wiggling and it will start to suck air through it...as is what happened to my X-Moto's 163FML. FYI-when this happens, the "quick fix" while you're waiting for your part is slather it with silicone, as in the pics.
I hit the web and lo and behold, found a permanent fix. An all aluminum intake manifold. I got it in about a week from China from Amazon and after a good carb disassembling and cleaning, it fit like a glove. It comes with an o-ring that seats against the head so make sure and use some white grease on it, as also the o-ring on the carb. Also, bolt the intake to the carb first, then fit it in if you have a tight frame. There is no more wiggle in the intake to wedge the carb onto the intake. For all the new folks with Hawks and Storms, this would be a good upgrade to do when you're upgrading the stock carb and breather, all at the same time and save yourself the repair later, if you have the same setup. Here's the link. Can't beat the price and shipping. http://www.amazon.com/Aluminum-Intak...ntake+manifold
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 12-31-2016 at 03:42 PM. |
03-24-2016, 11:23 PM | #2 |
good find!!! bought mine
03-25-2016, 01:15 AM | #3 |
Thanks for posting the great tip, 2LZ.
03-25-2016, 03:32 AM | #4 |
Mine had a pin sized hole in it I just put some super glue in it.
03-25-2016, 10:16 AM | #6 | |
I was really amazed at how well the piece fit.
03-25-2016, 10:36 AM | #7 |
and I bet it was chest level on a new lift when you installed it....(jealous)
03-25-2016, 10:40 AM | #8 |
Well hell yah!! ;-)
03-25-2016, 12:50 PM | #9 | |
