Old 01-07-2011, 09:40 PM   #16
Before you guys go any further, check your compression.
Remove spark plug. turn kill switch to off. Hold throttle wide open. Put thumb over spark plug hole and press hard. hit starter. If the compression does not smartly blow your finger off the hole that's not enough to run the motor. 100 PSI is the minimum to barely run. You should have over 150 PSI.
