ChinaRiders Forums
-   Dual Sport/Enduro (http://www.chinariders.net/forumdisplay.php?f=101)
-   -   DB-06 Engine Swap (http://www.chinariders.net/showthread.php?t=11511)
Weldangrind 08-20-2012 12:02 PM
Mmmm... cheddar popcorn.
I've loaded many dead bikes into Dodge Caravans over the years; I know what a struggle that can be. Now, I use a bike hauler on the Class III receiver, which just requires a couple of tie-downs. much easier.
Great job, guys! :D
TheGammaGhost 08-20-2012 03:47 PM
Okay, it's 100% put together...
Its not being as easy to start as i had hoped, Right away i tried the electric start, did it to much, and now it the electric start isnt working. it did sound like it could have started with it, if i had done it properly rather than just holding it.
Now im trying to kick start it. Very tiring, Going to keep trying, I hope i can get it!
TheGammaGhost 08-20-2012 04:07 PM
Can't seem to get it kick started, im trickle charging my battery right now to see if i can get it to that way.
Any tips?
FastDoc 08-20-2012 04:08 PM
Did you start it before the transplant? In it's orginal frame?
TheGammaGhost 08-20-2012 04:09 PM
I did not, wish i would have. they did state the engine was fine though.
TheGammaGhost 08-20-2012 04:12 PM
On the 3 cords that go from the engine to the bike, They all fit, but i did notice, the smaller plug, on the female end on my roketa, only had one pin, where as the lifan frame/body had more.
not sure if that could be it, i doubt it, it seems good, Maybe the spark plug? it says NGK on it.
FastDoc 08-20-2012 04:14 PM
1st things first.
Are you getting spark and fuel?
TheGammaGhost 08-20-2012 04:15 PM
How do i know if im getting spark? and i did hook the fuel up, and turned it on.
TheGammaGhost 08-20-2012 04:32 PM
Ahhhg, i dont know what to do!!!
FastDoc 08-20-2012 04:33 PM
Remove the plug from motor. Leave the cap/wire on. Rest base of plug on clean bare ground on chassis or engine. The head will do. Dim lights if possible and crank engine. A bright blue snappy spark should appear in the plug gap. Please test and report back.
TheGammaGhost 08-20-2012 04:36 PM
ok
TheGammaGhost 08-20-2012 04:41 PM
okay, tried both plugs, No spark.
FastDoc 08-20-2012 04:55 PM
There's your problem. Check CDI connections. Make sure kill switch is not stuck on or grounded. Check spark plug lead and connection to the cap.
TheGammaGhost 08-20-2012 04:57 PM
okay, ill go check it out right now. will report back shortly.
TheGammaGhost 08-20-2012 05:09 PM
CDI is all plugged in. How do i know if my killswitch is grounded or not?
