ChinaRiders Forums
-   Dual Sport/Enduro (http://www.chinariders.net/forumdisplay.php?f=101)
-   -   Lifan 200 GY-5 exhaust problem. (http://www.chinariders.net/showthread.php?t=11418)
Weldangrind 08-04-2012 01:35 PM
Originally Posted by Zombieking
WOOOOOooo, Turned out i didn't even need heat just a little wd-40 and a new pair of vice grips. Bought a 6mm stud and bolt. Now it's good as new. Thank you all for your help!
Awesome! It's a good idea to coat the stud with a little anti-seize before screwing it into the head, which will make it easier to remove next time. Also, I use two nuts per stud, because it allows you to jam them together. I haven't lost any that have been double-nutted.
Originally Posted by katoranger
Originally Posted by FastDoc
Git 'er done! 8)
Vise-Grips are one of the tools where the cheap knock-offs are not nearly as good as the real thing. I have MANY cheap Chinese tools but my Vise-Grips are the real thing. :wink:
x2. Channel Locks too.
X2 on the Channel Locks, X3 on the Vise Grips.
Frog 08-13-2012 04:04 PM
If all else fails it is a case of centre punch it and drill it out - then retap the hole - tricky because of getting the right alignment...:?
Frog
mike1346 08-20-2012 10:16 AM
Glad to see you got it out, I had the same thing happen on mine. I tryed to vise grips and only managed to chew it off little by little. I ended up finding a nut that would slide over it and welded it on. Added a little heat to the head and wrenched it out :)
