Carb/Throttle
My son complained about the thumb throttle being hard to use, so i switched to a twist. After a full weekend of riding, he was still complaining about the amount of force needed to twist the throttle, he rode many other thumb and twist machines during the weekend and did not complain about the force on them. is there anything I can do to make it easier, maybe a new/ different style carb. Falcon 150 GY6 style motor
I feel like you could shorten the spring on top of the slide as long as the slide closes consistently. I would order a replacement spring for your carb just in case before you do the work.
https://ae01.alicdn.com/kf/HTB1N1v1L...ER-GO-KART.jpg
this is what my carb looks like, I do not think i have a top spring |
Maybe the return spring visible on the left is wound to tight?
it is still really tight when I operate it at the carb
I recommend going back to a thumb throttle and adding an extender. My wife and I each have one.
coil
you can cut the spring down... just ( 1) spring wrap in the carb body... and try that... might be too strong.. make sure the thumb lever moves ok.. undo the throttle cable and try it by itself..
thanks for all the replies. I took the carb off and cleaned and lubed the butterfly it seems to move free, it had 1 wrap on the spring, cabl and twist moves good and free. I might modify the spring or might just give my kid roids(just kidding) he will get stronger as he go along. Is there a different style of carb that could be used, I see in the web there are some that has the throttle cable in the top of the carb.
wraps
when you say WRAPS .. what do you mean?? plastic tie wraps... or coils on the spring... a lot of problems are when you use plastic ties to hold the cable.. this stop the action of the throttle tension... make sure the cable itself work freely... and the thumb lever does not bind.. never really heard of this problem without it being sticky due to binding.. dry .. needing lube.. the barrel in the carb sticking by itself.. check it out.. the barrel and needle should be loose in the carb.. cable free to move.. only the spring on the barrel stops and returns the barrel..
Don't CV carbs typically have two cables?
by wrap i mean spring wrap. The spring was not wrapped/twisted to much. and the throttle cable opens the butterfly
