ChinaRiders Forums
-   ATVs (http://www.chinariders.net/forumdisplay.php?f=102)
-   -   2008 bmx utv (http://www.chinariders.net/showthread.php?t=17423)
cford 09-05-2016 09:36 PM
2008 bmx utv
I have a BMX utv that I am having an issue with the fuel system. The fuel filter is dry appears the fuel pump is not operating. How can I check this and then does anyone have a source to get a new fuel pump? Thanks !!!!!!!!!
david3921 09-05-2016 09:59 PM
Electrical or engine driven?
Adjuster 09-05-2016 10:28 PM
Have you checked for fuel in the tank?
Have you checked if fuel is making it to the pump?
Have you checked the petcock/fuel valve? Some are vacuum operated.
Some fuel tanks have a filter inside the tank where the fuel line attaches or at the end of the fuel pick up tube.
Pictures of the machine and engine will help us get you sorted out.
humanbeing 09-05-2016 10:52 PM
Powerwd by CFmoto 500 (CF188)?
The manual http://www.motorscoop.no/filarkiv/Fi...500_manual.pdf
