ChinaRiders Forums
-   Pit/Pocket Bikes & Scooters (http://www.chinariders.net/forumdisplay.php?f=111)
-   -   Scooter Jetting - First Time Advice? 150CC CY6 (http://www.chinariders.net/showthread.php?t=19601)
gmcjetpilot 07-28-2017 06:30 PM
OK I really like my BMS Prestige 150. However it is running lean (plug is white white white). My first UP jetting is described below. I'd like advice and comments (sage wisdom)....
Removed original 110 main and went in with 120 main, I skipped 115 since I am so lean. (what size jet should I go to if this is not enough. My choices are 125, 130, 135 & 140.
Removed original 32 pilot. I went in with 35 pilot, next size up with the jet kit I received. My next choices are 38, 40, 42, 45, 48, 50, 52 & 55.
Pilot Jet - Original was short, sat deep in the pocket it screwed into. New Pilot Jet is longer, mouth sits flush or slightly proud. (is this a big deal?)
Needle has a flat top and does not have clip ring adjustment.... (is this a needed mod, where you can adjust the height?)
I only took it on a short test hop. Seems to run fine, as usual. No top speed test. Still a little boggy in mid range acceleration, but overall same or slightly better.
Tried to go wide out recently with stock jets. At 150 miles on OD, I am still breaking it in. However I decided to try for top speed. 50 mph was it. Not impressed. Seemed fine at 45 mph, but I was surprised at low top end. I thought 55mph would be doable?
COMMENTS FOR A NEWBE RE-JET-ER....
