30mm Carb upgrade
Got the new carb and intake for the atv. Its an ebay "Mikuni". Looks like a pretty decent carb and is noticeably bigger than the stock carb. Figured I couldnt go wrong for $25. The flange on the new intake tube is not exactly a perfect mate to the carb, but its a 30mm hole in it so I tried it out.
After adding a high performance cdi unit for the first mod, I didnt really notice any difference, except it ran a little smoother. Now after adding the intake and carb I noticed a HUGE difference in power. I didnt try the carb out on the stock intake tube because the tube was much smaller than the opening on the carb so I figured it probably wouldnt run too well like that. I highly reccomend a carb upgrade if you're looking for more power. Mine became a totally different bike after the carb upgrade. Gonna do the exhaust next, I'm expecting that I'll see another huge jump in power after I open up the exhaust now that there is a lot more air and fuel going into the engine. Just kinda wanting to see how 1 mod at a time affects the engine and see which mod is the most bang for the buck. I'll keep everyone posted on the next one. Ron |
Thanks for your writeup; I can totally appreciate doing one mod at a time to quantify results.
Please tell us more about the intake tube. Do you have a photo? If it would work on my Beast, I'd be all over it. Do you have a link that points to it? |
Here's a link to the place I bought the intake tube from, it was an ebay special
http://cgi.ebay.com/ebaymotors/30MM-...Q5fAccessories If the link doesnt work, just go to ebay and type in the search box "Mikuni 30mm Intake", many different styles of intake tubes will show up. The carb didnt mate up too well on mine at the flange, it seems the flange is a little too small for the carb to mount on to it. Part of the o-ring is exposed but it did seal. I couldnt believe the difference it made, its like someone stuck a bigger engine in there while I had my back turned. |
if you can get your hands on a small peice of pyrex and a dremel.. you could very easly make a plate that will go between the intake tube and the carb for a better seal.. just put some high temp rtv (also known a gasket maker) on the pyrex adapter on the intake tube side to seal that up..
You did do the intake and carb at the same time you said? I wonder how much the tube matters more so than the carb?? Curious..
For a homemade carb spacer/adapter i use phenolic. |
if you can put your carb close to the motor you will make more power
I did do the intake and the carb at the same time, I figured if I'm gonna put a 30mm carb on it, I might as well have a 30mm hole all the way to the intake port on the head. The carb seems to be sealed, its not acting like its got a vacuum leak. its a very small part of the o-ring thats exposed...probably will cause premature failure on the o-ring though. I couldnt stand to wait to get a new silencer for it so I went ahead and pulled the end cap off the muffler today and went to work with a dremel and a drill. Turned out there was 2 baffles inside that I persuaded to come out. Just pulled those out of there and put the end cap back on. Looks totally stock now, but no spark arrestor :( and loud :twisted: It didnt make as much of a difference as the carb/intake upgrade, but it did seem to add a bit more power. Gonna get the FMF pipe eventually and stick it on there. I think a little back pressure is probably gonna do it some good and probably will gain a little more power. Plus I wouldnt mind a few less decibels.
Ron |
idle sound will get softer with the fmf and new packing.. trust me.. did it yesterday..
you need to rejet.. good rule of thumb and a good starting point.. go up 2 jet sizes for a new intake, and 2 jet sizes for a new silencer.. if you noticed or not idk.. but your intake filter should be hissing a little since opening up your muffler. its like this with jetting, if you slap a intake and full exhaust on a car.. you will notice a little more power.. but if you slap a intake and full exhuast and then get it tuned.. you will notice a good amount more power.. jetting is tuning for carbs.. as for silencers i would suggest a powercore 4, tubine core.. also if you want a softer sound order the quite insert with the silencer.. also order a wash plug for the muffler, getting water inside to the packing will destroy it faster.. wash plugs are like 5 bucks a pop |
Ya I was a little worried about running it too lean by opening up the exhaust. It runs really good but I'm sure its a little lean now. That'll be my next thing to do....I'll jump up a few jet sizes and see what the spark plug looks like. I pulled the jets out to look at em and didnt write down the numbers :x I think I remember the pilot jet having a 20 on it and I cant remember what the main jet was...ugh
Ron |
Is there a "universal fit" type FMF pipe? or do I need to find one made for a Honda or whatever that has a somewhat similar exhaust system?
i think the stock mikuni main is 90 or maybe 100
its always a little safer to run a tad rich then it is lean.. but to rich can give problems too do you have any back firing ? ive noticed on mine at about 1/8 to 1/4 throttle, i have a fast rapid back firing that clears out once i hit full throttle.. at first i thought thats how the muffler sounded but after hearing it a few times its a super faster rapid backfire.. |
Not getting any backfiring. I believe the main jet was 100 now that you mention it.
Ron |
