Old 03-10-2011, 02:32 PM   #1
azriel   azriel is offline
zongshen carb diaphragm problem!
Hy guys! Well i have a problem... :(
My zong uses a tekei 28mm carb with a diaphragm as you all know...
The problem is-after i removed the top black cap to inspect the diaphragm and ensure its undamaged i tried to put it together and its about 2 mm too big all around the carbs body. 8O
I succeded to put it together using a small flat screwdriver while appling pressure on the cap where the diaphragm seated in the groove so it couldnt pop out again.
Bike works good,idles good,rides good... :?
The question is,if its not seated good (diaphragm) could the bike start,idle and run without showing some major problems?
Is there any spare diaphragms to buy (and where) or is interchangeable with some other carb diaphragms?
Here in Croatia i can only buy a new TK carb, no spare parts!!! :evil:
Can i switch TeiKei with Mikuni mv24 28mm carb that doesent use a diaphragm?
Thanks for your answeres!
