Old 12-27-2012, 10:18 PM   #38
If you are feeling lazy, or are intimidated by doing this, you can remove the gas tank unscrew the top of the carb and remove the slide and spray carb cleaner down through the main jet until it starts flowing out the over flow tube of the carb. also spray it down any other holes you can see from this perspective. there will likely be a small hole towards the engine that is for the idle jet, spray it well.
Great shortcut, WA. I'll have to remember that one. :wink:
