Old 05-13-2013, 03:22 PM   #5
Originally Posted by FastDoc View Post
I don't recally my Q's using or needing a paper gasket. If there's the appropiate O-ring you're good to go.
Mine either. I've seen some with but I've never had a leak. Just rub some new oil on the O-ring like you do with a spin-on oil filter and you're good to go.
Don't know much about the cables, though. I do know that a speedo cable for a DR200 fits. You might be able to find a bicycle cable that matches as the ends are quite similar. I used one on a jetski when I switched to a finger throttle and it held up fine.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
