Originally Posted by AnimalTk
If I connect all four LEDS, as well as use an LED rear brake, will the removal of the indicator bulb (the blue light next to the high beam and neutral indicator) make everything work properly? I want this thing street legal for the weekend!
Yes,
two LED turn signals and an LED tail light will work if you remove the turn signal indicator bulb.
Four LED turn signals will work
only if you remove the bulb
and install an LED flasher.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
