I use a sharp pick to remove the dust seals and the free needles from the lower shock bearing, which is at the front of the rocker/knuckle/arm. I purchased the following pick set from Harbor Freight, which comes in handy for many jobs.
http://www.harborfreight.com/4-piece...set-66836.html
You can apply grease to the bearings with your fingers, or small brushes. I usually employ small shop brushes, which I also bought from Harbor Freight.
http://www.harborfreight.com/36-pc-1...hes-61880.html
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
