My rear sproket is loose... any sugestions
Was adjusting the chain tension.. and discovered that all 4 bolts are loose on the rear sproket. The nuts have not come loose.. the stud pulls in and out of the hub assembly.. Are they pressed in from the front.. or are they bolts that come thru from the back and stick out thru the front. I checked the parts diaghram but it is not detailed enough.. Just thought I would ask before pulling the rear wheel and disassembling it to find out.
Thanks..
Ken
