Originally Posted by PNWDualRider
UPDATE*** I took off the sprocket cover to see if I could see anything wobble and I shifted through some gears and it seems to have disappeared which leads me to believe it might be a transmission thing. I wonder if I broke some teeth off the sprockets in the gearbox because when accelerating from a stop, it seems like it has to grind and then catch in first gear to get going...
Odds are you may have picked up something on the chain (piece of gravel, etc.) and ran it through the countershaft sprocket, would be my guess.
I'd imagine that busting a tooth off a gear is virtually impossible, especially with the mammoth HP that these put out. ;-)
Also, it's normal for the CG motor countershaft sprocket to wiggle. That's why I'm not concerned about running a flat sprocket on the rear and having the length of the chain make up the 4mm +/- offset.....or "we'll see".
Keep us posted.
