Installation of RX3 Engine in Motorcycle
Install Engine in Motorcycle
Place Hydraulic jack under Engine
Raise engine into frame
Install swingarm bolt
Install both bolts at rear of engine
Install upper bolts connecting rocker cover to engine frame
Install the two bolts connecting the intake manifold to the cylinder head
Install Clutch Cable, Shift Lever and Hoses from Engine
Install Clutch Cable to Left Crankcase Cover
Install the Oil Contaminant Separator (OCS) on Engine
Install Shift Lever
Install Electrical Connections to Engine
Connect power wire to starter motor
Connect Ground Wire
Connect stator and pickup coil wires
Connect gear indicator wire
Install MAP/MAT Sensor to Intake Manifold
Install Ignition Coil to Frame
Install Spark Plug Boot onto Spark Plug
Install Left Radiator
Install upper hose from Thermostat Housing
Connect fan electrical wire to wiring harness
Install Right Radiator
Install lower hose from water pump on right radiator
Install upper hose to right radiator
Install hose from Thermostat Housing to Cylinder Head
Fill radiators with coolant
Install Exhaust Header and Perimeter Engine Bracket
Install lower engine bolt of perimeter engine bracket
Install Radiator Mounting Wings and both top bolts of perimeter engine bracket
Install two bolts on rear of perimeter engine bracket
Install upper engine bolt of perimeter engine bracket
Install both bolts for both radiators
Install rear brake pedal
Connect wires for auxiliary lights on perimeter engine bracket
Install Fuel Tank
Install fuel tank
Install upper engine guard and connect wires to auxiliary lights
Install fuel tank fairings
Install plastic side covers
Install main saddle
Install pillion saddle
Install Progressive Shock Linkage and Rear Tire
Remove Swingarm Bolt
Install shock link on engine frame
Install Drive Chain on Counter Shaft, and install Swingarm
Install the shock absorber into the frame with the upper bolt
Install the rocker arm onto the swingarm, and torque bolt to 38 foot-pounds
Install Lower Shock Bolt into rocker arm, and torque to 33 foot-pounds
Install rear bolt to link/dogbone, and torque to 38 foot-pounds
Install rear brake caliper onto swingarm
Install Rear Wheel
Replace Motor Oil and Engine Coolant
Install Engine Coolant
Fill Engine with 1.7 Quarts of Motor Oil
"Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![Wink](images/smilies/windfk.gif) Mark Twain
